jens wrote:What do you write into the camera setting?
cant get it to work .
//Jens
jens wrote:Thanks now its working .
siclark wrote:jens wrote:Thanks now its working .
haha thats ok. a I had the same problem.
jrickmd wrote:Shavano wrote:Colorado4Wheeler wrote:
I have updated to 0.18.0 and continue (present since I installed HomeKit Bridge 0.17.2) to have a glitch with a temp sensor. No matter what setting I use for the HomeKit Bridge server (C° or F°) HomeKit appears to always assume that it is getting a temp in C° and converts to F°…and currently shows as 162° (no units) in the Home app. I assume that I'm doing something wrong, but can't seem to find the answer in the documentation.
I had same problem,. Go into your server device and edit the settings. Then select each of your thermostats and "Edit single device". Then select the F settings there and save. Give HomeKit a couple of minutes to update and all was good for me.
durosity wrote:I noticed last night that if i issue a command like "Turn off the master bedroom lights" HBB will do these all in near syncronisation, but HBK will do them sequentially.
blysik wrote:In HKB, will there be a a configuration where I can support these? Thanks.
