Colorado4Wheeler wrote:Garage doors aren’t yet working. There are still a lot of devices to incorporate, including doors.
autolog wrote:I think it would be useful (in the fullness of time) to emulate what is done in the Alexa-Hue Bridge (which emulates Indigo's Virtual devices). That is to be able to specify On, Off and Dim Actions and store the dim value in a variable. That would allow users using the Alexa-Hue Bridge to use the same actions in your plugin as well.
Just a suggestion
HomeKit Bridge Warning DEVELOPMENT TEST FUNCTION ACTIVE
HomeKit Bridge Error Exception in homekit.deviceInitialize line 595: local variable 'obj' referenced before assignment
CODE: self.alias.value = obj.name
HomeKit Bridge Error HomeKit server 'Test' could not be started, please check the service logs for more information, now issuing a forced shutdown of the service to be safe.
HomeKit Bridge Attempting to stop 'Test'
HomeKit Bridge HomeKit server 'Test' has been stopped
HomeKit Bridge Error send "Test" on failed
Colorado4Wheeler wrote:autolog wrote:I think it would be useful (in the fullness of time) to emulate what is done in the Alexa-Hue Bridge (which emulates Indigo's Virtual devices). That is to be able to specify On, Off and Dim Actions and store the dim value in a variable. That would allow users using the Alexa-Hue Bridge to use the same actions in your plugin as well.
Just a suggestion
It's a good suggestion and I am open to all suggestions! I don't want to put it in the server config only because one of my goals with this plugin is to make it bulletproof in setup, no extra "stuff" to make it harder for the average bear to figure out. I'm not the average bear and the Alexa options are a bit overwhelming for me sometimes. That being said, it's also been on the roadmap from day 1 to have a way for advanced users to tweak device settings, such as what on/off/dim would do instead of the default. I've debated doing that in another plugin (likely Device Extensions) or doing it here, but again I want purity in this plugin and not inundate it with all sorts of other crap that might just break it. As it sits this plugin is a pretty complex piece of coding, if I were to do too much more than serve up HomeKit I fear that it would destabilize it or water down the core function.
Does that make sense?
autolog wrote:The slider in the Home App goes from 10 to 38.
Can the range either be specified or have a lower limit.
autolog wrote:Would it be possible to define an Action Group as a Homekit Scene.
Different Computers wrote:I've deleted the bridge, recreated it with no devices, still no go.
Different Computers wrote:I find the Include menu for the bridge to be SUPER awkward and unintuitive
Different Computers wrote:I have literally hundreds of devices that I don't want to be included, so it's pretty tedious
Different Computers wrote:I don't see any way of making devices that weren't in the first 99 appear.
Colorado4Wheeler wrote:I don't have an Alexa, but if I did, I'm sure I would find it so. Sorry if I sounded harsh.Do you find the Alexa SUPER awkward and tedious as well? .
Different Computers wrote:Sorry if I sounded harsh.
Colorado4Wheeler wrote:Your complaint gives me an idea for having an exclusions list too..
