Indigo 6 Beta 5 Released
Fri Jan 25, 2013 3:19 am
6.0 Beta 5 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added support for new international 240V SwitchLinc Dimmer (2478D) and Mirco Modules Dimmer and Relay.
  • Added support for new INSTEON module: revised Outdoor Appliance (2634-222).
  • Added a couple of new contextual menu items:
    • When you right click on any of the main objects in the Home Window or the Variable List, Copy Python Reference will copy out the following string that you can paste into a Python script: indigo.objecttype[ID] # "Object Name". Note included is the object's name in a comment after the actual command to help with script readability.
    • When you right click on any of the main objects in the Home Window or the Variable List, Copy AppleScript Reference will copy out the following string that you can paste into an AppleScript: objectype named "Object Name".
    • When you select any ID inside the embedded script text area and right click it, a new menu item is added at the bottom that will tell you the name of the object corresponding to the ID and for most types when selected it will open the edit dialog for that object. Variable names are shown but grayed out since there is no edit dialog for variables.
  • Added new features to embedded script text area: undo/redo is now enabled, and in Lion or better the find functionality is now presented in an embedded find bar in the text area itself.
  • Improved Prism Reflector reliability, performance and security.
  • Made the registration code selectable in the About dialog for use in copy/paste operations.
  • Lowered minimum setpoint value allowed for INSTEON compatible thermostats from 10 degrees to 1 degree.
  • Fixed bug that allowed Indigo client UI to delete the read-only isDaylight variable in some cases.
  • Fixed bug that caused Device dialog to show incorrect X10 house code and device codes in some cases (house code M, device code 13).
  • Fixed bug that could cause some plugin device properties to revert to previous values when Device dialog was closed.
  • Fixed bug that could cause the Trigger dialog to show two copies of the plugin settings UI window at the same time.
  • Fixed bug that could cause the INSTEON/X10 Power Line config dialog and the X10 RF config dialog to incorrectly report a port conflict.
  • Fixed bug that would cause a folder to be deselected when renamed in the outline view.
  • Device Collection: added some extra debugging and a "Toggle Debugging" menu item that will show more of what's going on in the plugin.
Developer API Changes:
  • Plugin API version number has been incremented to v1.5.
  • Plugin API addition: Added new serialPorts menu list filter to show modem type serial devices in the UI: indigo.showModems.
  • Plugin API improvement: Device types defined by plugins will now appear in the order they're declared in the Devices.xml file in the Model popup in the Device Edit dialog.
