Indigo 5 v5.1.1 Released
Fri Apr 27, 2012 12:38 pm
v5.1.1 is now available for download.
In addition to the major version 5 improvements this update includes these enhancements:
  • Added new INSTEON Commands plugin with various useful INSTEON device commands.
  • Added Disable 2414U internal daylight saving time calculations option to 2414U interface options UI. This option should be turned ON if you use the 2414U interface outside of the U.S. / Canada.
  • Added new device images to Control pages: "Thermostat Mode+.png", "Thermostat Fan Mode+png", "Fanlinc+.png", and "Garage Door+.png". See Action Collection additions below some for related actions.
  • Modified device dialog model name for FanLinc to be less ambiguous.
  • Fixed bug that caused Greater Than and Less Than device state conditionals to incorrectly evaluate in some cases.
  • Fixed bug that would cause INSTEON I/O-Linc links to sometimes not respond correctly to OFF scene commands.
  • Action Collection plugin: added three new actions: Cycle Through Thermostat Modes, Toggle Thermostat Fan Mode, and Cycle Through Speed Control (FanLinc) States.
  • Plugin API addition: Added plugin self.stopPlugin() method so plugins can request that IndigoServer disconnect and stop themselves.
  • Plugin API addition: Implement Info.plist ServerApiVersion checking. The current ServerApiVersion is 1.0. Plugins should increment their required ServerApiVersion when/if they start using APIs that are new/modified after Indigo v5.1.1.
  • Plugin API improvement: Fixed bug that caused .py plugin action script calling to fail in some cases when a deviceId argument is used.
