Indigo 3.0.0 Beta 16 Released
Sun Feb 10, 2008 8:18 pm
3.0.0 beta 16 is now available for download (the DMG is here). Note this beta will force you to save a new copy of your database after it converts it. Backup the IndigoWebServer folder if you have made any custom modifications to the HTML templates or Python code. This beta installs several IndigoWebServer improvements which may overwrite any custom changes.
Details about the INSTEON Link Management are here and the PowerLinc V2 (2414U) upload support are here. Updates in this beta include:
  • Added support for INSTEON Thermostat Adapter.
  • Added AppleScript INSTEON verbs: send insteon group, send insteon remote poke, send insteon powerlinc set button pressed.
  • Added AppleScript thermostat device properties: supports hvac, temperatures, humidities, heat setpoint, cool setpoint, hvac mode, fan mode.
  • Added AppleScript support for "with transaction" blocks to provide server suppressing of interface command sending and logging.
  • Added AppleScript transaction block verbs: transaction suppress logging, transaction suppress state change sending.
  • Added Always send group/scene cleanup messages option to the PowerLinc interface options dialog.
  • Modified AppleScript verb remove delayed actions for trigger to remove delayed and auto-off actions based on the originating Trigger or Time/Date Action's name.
  • Improved Trigger and Time/Date Action Suppress logging checkbox option to prevent logging of contained actions (not just the Trigger label).
  • Fixed bug that caused some remote EZIO module settings to not be saved across power outages.
  • Fixed bug that sometimes caused server hang if USB to serial adapter was unplugged while Indigo was connected to the interface.
  • Fixed bug introduced in beta 14 that caused some INSTEON All Button commands to incorrectly trigger Trigger Actions for button/group 1.
