Indigo 7.1 Release Notes
Tue Oct 17, 2017 11:17 pm
7.1.0 is now available for download. For an overview of the changes in this version, see our blog announcement here. Note this version no longer uses registration codes but instead will prompt for your Indigo Account authentication on first launch. This authentication process only happens once – you will not be prompted when installing future updates.
Maintenance releases of Indigo 7.1 (7.1.1, etc) are outlined below this post on this forum topic.
This update adds support for the following home automation devices:
  • Aeotec Garage Door Controller (ZW062).
  • Aeotec Nano Dimmer with Energy Reporting (ZW111).
  • Aeotec Nano Switch (ZW139).
  • Aeotec Nano Switch with Energy Reporting (ZW116).
  • Aeotec Dual Nano Switch (ZW140).
  • Aeotec Dual Nano Switch with Energy Reporting (ZW132).
  • Aeotec WallMote (ZW129).
  • Aeotec Water Sensor 6 (ZW122).
  • Aeotec Recessed Door Sensor (ZW089) - additional model ID variant.
  • Aeotec Smart Energy Switch (ZW075) - additional model ID variant.
  • Aeotec Heavy Duty Switch (ZW078) - additional model ID variant.
  • Black Cat Motion Sensor (ZWBCCE21S).
  • Duwi Key Fob (ZME-KFOB) - additional model ID variant.
  • Ecolink Garage Door Tilt Sensor (TILT-ZWAVE2).
  • Everspring Appliance Module (AN163).
  • Fibaro Door/Window Sensor 2 (FGDW002).
  • Fibaro Wall Plug Relay (FGWP102).
  • Fibaro Keyfob (FGKF601).
  • Fibaro Double Switch 2 (FGS223) - additional model ID variant.
  • Fibaro Door/Window Sensor (FGK10x) - additional model ID variant.
  • FortrezZ I/O Module (MIMO2+) - additional model ID variant.
  • FortrezZ Water Valve (WV01) - additional model ID variant.
  • FortrezZ Water/Temperature Sensor (FTS05).
  • Heiman Door/Window Sensor (HS1DS).
  • Heiman Motion Sensor (HS1MS-Z) - preliminary support.
  • Horstmann Temperature Sensor (SES302/SES303).
  • Neo CoolCam Door/Window Sensor (NIP28).
  • Neo CoolCam Double Relay Switch (NAS-SC01Z).
  • Neo CoolCam Motion Sensor (NAS-PD02Z).
  • Neo CoolCam Siren.
  • Neo CoolCam Smart Power Plug (NAS-WR01ZE) - preliminary support.
  • Neo CoolCam Water Sensor (WS01Z) - preliminary support.
  • Philio Multi Sensor (PAT02-B).
  • Stelpro Thermostat (STZW402+).
  • Yale Keyfree Connected Lock.
  • Zipato Multi Sensor 4 in 1 (ZD2201).
Additional improvements include:
  • Added Z-Wave internal (scriptable) action to assign return route for nodes.
  • Added Z-Wave module address (node ID) information to progress messages.
  • Added Z-Wave filter logic to prevent logging of duplicate Aeotec Multi Sensor value messages.
  • Added tamper switch device for Vision Siren (AM1601). Re-Sync the device to update the UI shown.
  • Added main window device search/filtering on model and protocol names.
  • Added support for a new Web server public (no authentication used) folder path.
  • Improved Web server caching for both browsers and Indigo Touch.
  • Improved decoding of UTF8 python script files.
  • Improved Z-Wave support for LinearLinc Garage Door Controller (GD00Z-2, GD00Z-4).
  • Improved Z-Wave support for POPP Smoke Detector and Siren (004001) so that smoke device state is updated correctly on detection.
  • Improved Z-Wave support for some Schlage BE369 locks that require group #2 association for broadcasting state changes.
  • Modified response to Z-Wave low battery messages to change the device's battery level to 5% (versus previous 0%).
  • Modified SQL Logger plugin to prevent device state and internal column name collisions.
  • Modified Z-Wave power (Watts) states to allow for negative values (useful for solar/wind systems).
  • Modified Z-Wave NuTone Garage Door Controller (NGD00Z) definition to fix problem that caused the open/close actions to be ignored.
  • Modified Z-Wave Vision Garage Door Tilt Sensor (ZG8101) definition to enable support for Tamper Switch.
  • Modified Z-Wave Vision Zooz Multi Sensor (ZSE40) definition to allow lumincance sensitivity to be disabled (set to 0).
  • Modified Z-Wave Aeotec Home Energy Monitor (ZW095) UI to allow polling every 30 seconds (previous minimum was every 2 minutes).
  • Modified lower bounds for white temperature UI slider to 1200.
  • Fixed bug that would cause (on some Macs) start local server setting changes to be ignored on server restarts.
  • Fixed sunset and sunrise calculation error that would happen at some locations.
  • Worked around bug in Z-Wave Aeotec ZW095 module (3 clamp version) that causes it to fail to sync with Indigo.
  • Airfoil Pro Plugin: added correct error message when trying to restore speaker states before states are saved.
  • Airfoil Pro Plugin: tweaked menu item name to indicate that selecting it will open a dialog.
  • WeatherSnoop Plugin: fixed unicode character issue when creating a device for an agent that contains unicode characters.
Developer API Changes:
  • Fixed bug that prevented serialport type Field inside ConfigUI elements from working correctly inside DeviceFactory elements.
  • Plugin API addition: Added new device instance properties, WhiteTemperatureMin and WhiteTemperatureMax, which can be used to define the lower and upper bounds of the white temperature UI slider.
Tue Nov 07, 2017 8:55 pm
Indigo 7.1.1 Release Notes
7.1.1 is now available for download. This update includes the following changes:
  • Added Z-Wave scene command filtering of incoming duplicate packets.
  • Modified control page refreshing images to allow for file URLs that are missing forward slashes.
  • Modified Z-Wave Philio Multi Sensor (PAT02-B) device definition to force binary sensory report sending on initial sync.
  • Modified Z-Wave Aeotec Home Energy Monitor (DSB09104) UI to allow polling every 10 seconds (previous minimum was every 2 minutes).
  • Improved error reporting of corrupt endpoint packets from Z-Wave interface.
  • Fixed bug that would cause the Indigo client to show a "folder permissions are not correct" error alert when running on a Mac that does not have the Indigo server installed on it.
  • Fixed bug that would cause the PowerLinc re-sync notification alert to show even after the PowerLinc had been disabled.
  • Fixed bug that would cause devices that report Volts / Amps to potentially override Watt / kWh state values.
  • Fixed bug that would prevent FortrezZ Water/Temperature Sensor (WWA02AA) flood sensor from being detected by Indigo.
  • Fixed crash in the Indigo client that would occur immediately after macOS showed the "Do you want to restore the windows" alert following a crash.
