Indigo 7 v7.0.3 Release Notes
Thu Jan 26, 2017 1:20 pm
7.0.3 is now available for download.
In addition to the major 7.0 improvements this update includes:
  • Added Z-Wave support for Dragon Relay Switch (WS100+) and Dimmer Switch (WD100+).
  • Added Z-Wave support for LinearLinc Garage Door Controller (GD00Z-2, GD00Z-4).
  • Added Z-Wave support for NuTone Garage Door Controller (NGD00Z).
  • Added Z-Wave support for additional variant of the Aeotec Multi Sensor (ZW074).
  • Added Z-Wave support for additional variant of the Everspring Flood Sensor (ST812).
  • Added Z-Wave support for additional variant of the Fibaro Button (FGPB101).
  • Added Z-Wave support for additional variant of the Fibaro Dimmer 2 (FGD212).
  • Added Z-Wave support for additional variant of the Fibaro Door/Window Sensor (FGK10x).
  • Added Z-Wave support for additional variant of the Remotec Scene Master (ZRC-90).
  • Added Z-Wave support for additional variant of the Vision Zooz Multi Sensor (ZSE40).
  • Added tamper switch device for POPP Solar Outdoor Siren (005107). Re-Sync the device to update the UI shown.
  • Added configuration parameter 1 to Z-Wave Everspring ST815 settings UI.
  • Added option to write Z-Wave device details to Event Log for all devices.
  • Improved/fixed Z-Wave device definitions for Qubino models ZMNHBD, ZMNHDD, ZMNHAD, and ZMNHND.
  • Fixed UI display bug that caused Indigo Touch to display "interface disabled" for X10 RF modules when using a W800RF32 or MR26.
  • Fixed Z-Wave library bug that caused rain rate sensors to show incorrect units.
  • Fixed Z-Wave library bug that caused ID Lock (101) to not correctly show and update locked/unlocked states.
  • Fixed Z-Wave library bug that caused Danfoss Thermostat Room Sensor (Link RS) temperature values to not update.
  • Modified Z-Wave library to not log received battery level commands for devices that have communication disabled.
  • Modified Indigo to be less verbose about logging incomplete Z-Wave packet errors.
  • Updated Multi Sensor 6 (ZW100) configuration UI to allow for changing motion sensitivity.
  • Optimized Indigo GUI to use integrated graphics GPU (versus discrete GPU) for improved battery life on newer laptops.
  • Removed ESC and Cmd-. shortcut keys from Control Page editor dialog to prevent accidental loss of changes.
Developer API Changes:
  • Fixed bug in indigo.zwave.sendConfigParm() API that would prevent paramValue arguments over 65535 from being accepted.
