Indigo 6 v6.1.5 Released
Thu Jan 21, 2016 2:01 pm
6.1.5 is now available for download.
In addition to the major 6.1 and major 6.0 improvements this update includes:
  • Added support for new INSTEON Thermostat with Heat Pump (2732-242, 2732-442, 2732-542).
  • Added support for additional version of INSTEON Mini Remote.
  • Added support for additional variant of INSTEON ICON On/Off Switch.
  • Added Z-Wave support for new firmware version of Fibaro FGMS001 Multi Sensor.
  • Added Z-Wave support for new version of DSC Multi Sensor (SNS-MS-DHS / DHS-ZW-SNMT-01).
  • Added Z-Wave support for Popp & Co. Remote Switch (9303).
  • Fixed bug that could cause Indigo to override the LED mode setting of Z-Wave GE relay modules after they had been manually changed.
  • Airfoil Plugin: Fixed bug where the plugin would fail when no source was selected (which wasn't possible in earlier Airfoil releases).
    Developer API Changes:
    • Plugin API version number has been incremented to v1.20.
    • Plugin API addition: Added new read-only attribute ownerProps to the base Device class that is a shortcut to the owning plugin's (the plugin that created the device) globalProps dictionary data.
    • Plugin API addition: Added optional attribute multiplierVarId to the SprinklerAction class which specifies the elem ID for the optional variable multiplier (None if no variable multiplier is specified).
    • Plugin API fix: Device enumerators (both via indigo.devices iterators and UI XML <Field> lists) now ignore devices that are not yet configured.
    • Plugin API fix: Device lastChanged property is now updated on INSTEON heartbeat broadcasts.
    • RESTful API: Fixed bug that could cause malformed JSON output.
