Indigo 6 v6.1.3 Released
Tue Aug 18, 2015 4:07 pm
6.1.3 is now available for download.
In addition to the major 6.1 and major 6.0 improvements this update includes:
  • Added checkbox to suppress logging of power/energy broadcasts from several Z-Wave modules (Aeotec, Fibaro, and TKBHome modules).
  • Added support for additional version of INSTEON Mini Remote (2342-242 aka RemoteLinc 2 Switch).
  • Added support for additional version of INSTEON 8 Watt LED Bulb (2672).
  • Added support for newer version of the INSTEON Lock Controller (2862-222). Setup/configuration is the same as the previous MorningLinc controller.
  • Added Z-Wave support for Aeotec Recessed Door Sensor (ZW089).
  • Added Z-Wave support for Fibaro Double Relay (FGS222).
  • Added Z-Wave support for LinearLinc LED Bulb (LB60Z-1).
  • Added Z-Wave support for Remotec Thermostat (ZTS-110).
  • Added Z-Wave support for additional variant of Aeotec Multi Sensor (DSB05).
  • Added Z-Wave support for additional variant of Fibaro Smoke Sensor (FGSS001).
  • Added Z-Wave support for additional variant of Remotec IR Thermostat Bridge (ZXT-120).
  • Improved handling of Mac sleep/wake cycles to suppress logging of errors as services become unavailable.
  • Fixed bug that could cause Indigo's Z-Wave communication to reset upon receiving specific packets from some sensor modules.
  • Fixed compatibility problem with INSTEON Smartenit ZBPCM module that caused kWh reported to be incorrect.
  • WeatherSnoop Plugin: fixed bug that caused a failure when a non-ASCII character was found in some of the WeatherSnoop data.
