Indigo 6 v6.1.1 Released
Thu Jun 11, 2015 10:29 am
6.1.1 is now available for download.
In addition to the major 6.1 and major 6.0 improvements this update includes:
  • Added ability to change I/O-Linc input behavior so that ON translates to OPEN and OFF to CLOSED by unchecking the "Legacy input sensor logic" checkbox in the device settings dialog. This is particularly useful when trying to use device state images on Control Pages. Note if you uncheck this you will need to send a status request to refresh the UI, and you will need to update any Device State Changed type of Triggers because open/close states will be reversed from previous behavior.
  • Added support for specifying an optional port number when connecting to PostgreSQL databases from the SQL Logger plugin (use format ip_address:port_num).
  • Added Z-Wave support for Aeotec Smart Energy Switch (ZW075).
  • Added more device settings for Aeotec Energy Switch 2nd Edition (DSC24).
  • Added ability to create Triggers on low battery broadcasts from RemoteLincs. Re-Define/Sync (not just resync) RemoteLinc devices to add the needed linking information.
  • Increased accepted parameter maximum value for Z-Wave Remotec ZXT-120 configuration parameter "IR code number" from 255 to 65535.
  • Improved the Z-Wave FortrezZ Water/Temperature Sensor module (WWA01AA / WWA02AA) definitions to poll the temperature sensor values during wake intervals.
  • Virtual Devices Interface: fixed a bug that occurred when deleting a device that is contained in a device group.
  • Vera Bridge Plugin: adjusted to a Vera API change that could cause some partial updates to fail.
  • Vera Bridge Plugin: added some extra debugging to identify when an update is received for a device that's either not in Indigo or is disabled.
  • WeatherSnoop Plugin: worked around an API issue in WeatherSnoop 3.1.1.
