Indigo 6 v6.0.19 Released
Posted: Thu Jan 01, 2015 3:53 pm
6.0.19 is now available for download.
In addition to the major 6.0 improvements this update includes:
Developer API Changes:
- Added Z-Wave support for the Enerwave Outlet (ZW15R) module.
- Added Z-Wave support for additional variant of Fibaro Motion Sensor (FGMS001).
- Added Z-Wave configuration UI for Trane thermostat model TZEMT400AB32MAA.
- Added logic to suppress DNSServiceProcessResult error messages to once every 12 hours.
- Improved handling of Z-Stick reporting missing modules.
- Improved support for Z-Wave Fibaro FGD211 scene triggers.
- Removed limitation on how long a speech phrase can be (previously limited to 512 letters).
- Enabled Turn On and Turn Off buttons in the UI for the Fibaro Smoke Sensor (FGSS001) so that Indigo's state can be manually reset to OFF after an alarm.
- Fixed bug that caused Indigo Web Server plugins to fail to load properly when optional Web server app_root_path parameter is set.
- Fixed bug that could cause crash if plugin UI had control visible bindings with values that contain space characters.
- Fixed Trigger and Schedule conditional bug that caused "date not equal" to fail to evaluate correctly in some cases.
- Fixed bug that would cause non-verbose action descriptions to be displayed for some plugin actions.
- Plugin API version number has been incremented to v1.18.
- Plugin API addition: Support for configuration UI to show error alerts (via errorDict["showAlertText"]) on button callbacks.
- Plugin API addition: New device instance attribue displayStateImageSel and method dev.updateStateImageOnServer(indigo.kStateImageSel.XYZ) for inspecting and overriding which state image icon is shown in Indigo Touch and the client UI.
