Indigo 6 v6.0.15 Released
Fri Sep 19, 2014 12:09 pm
6.0.15 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave support for Aeotec Smart Energy Strip (DSC11).
  • Added Z-Wave support for Cooper Dimmer Switch (RF9540) and Remote Switch (RF9517).
  • Added Z-Wave support for Everspring Smoke Alarm (SF813-2).
  • Added Z-Wave support for Merten Connect Move Switch (5082xx).
  • Added Z-Wave support for Siegenia Aubi Carbon Monoxide Sensor.
  • Added Z-Wave support for TKBHome Multi Sensor (TSM01).
  • Added Z-Wave support for additional variant of 2GIG Thermostat (CT100).
  • Added Z-Wave support for humidity sensor on the Z-Wave Trane thermostat.
  • Added configuration parameter UI for Fibaro Motion Sensor "Off delay" duration setting.
  • Added support for older INSTEON ControLinc model.
  • Improved usability of selecting Z-Wave node IDs that are currently used during sync (useful for hardware replacements).
  • Improved device dependency reporting for devices in groups.
  • Improved UI descriptions for variable actions.
  • Modified processing of Fibaro Motion Sensor (FGMS001) messages to avoid duplicate status update logging.
  • Fixed bug that prevented web registration from working correctly.
  • Fixed bug that would cause some plugin actions to incorrectly report dependencies on devices.
  • Timers and Pesters plugin: optimized state updates.
Developer API Changes:
  • Plugin API version number has been incremented to v1.17.
  • Plugin API addition: configuration UI popup menus can now specify separator menu items ("%%separator%%") and disabled menu items ("%%disabled:Item Text Here%%").
