Indigo 6 v6.0.12 Released
Thu May 15, 2014 10:01 pm
6.0.12 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave Modify Configuration Parameter menu command and action.
  • Added Z-Wave Send Raw Z-Wave Command menu command and action.
  • Added Z-Wave support for Danfoss Living Connect (LC-13).
  • Added Z-Wave support for Fibaro Motion Sensor (FGMS001).
  • Added Z-Wave support for Fibaro RGBW Controller (FGRGBWM), including a new Z-Wave Set RGB Levels action type.
  • Added Z-Wave support for TKBHome Smart Energy Appliance Module (TZ88E).
  • Added Z-Wave support for Vision Door/Window Sensor (ZD2102).
  • Added Z-Wave support for additional variant of Duwi battery powered Dimmer Switch (ZME-6443).
  • Added Z-Wave support for additional variant of Fibaro Door/Window Sensor (FGK101).
  • Added Z-Wave support for additional variant of Fibaro Door/Window Sensor (FGD211).
  • Added Z-Wave support for Fibaro Dimmer Switch (FGD211) 3-Way mode parameter (parameter #17).
  • Added millisecond precision to Event Log file (but not window) time stamps.
  • Insert into variable actions now insert clearer error messages into the Event Log when the variable no longer exists.
  • Fixed bug in the Run Shell Script action that would repeatedly show an error returned by a script.
  • Fixed bug that would prevent SyncroLinc device state/UI from updating correctly from a status request command.
  • WeatherSnoop Plugin: Fixed bug that kept new API fields from being added to the states list.
  • Airfoil Plugin: Fixed bug that made volume increases fail.
  • Vera Bridge Plugin: Fixed bug that skipped some scenes when loading them from the Vera.
