Indigo 6 v6.0.11 Released
Tue Mar 04, 2014 4:15 pm
6.0.11 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave support for Aeotec Energy Switch 2nd Edition (DSC24-2E).
  • Added Z-Wave support for Popp & Co. Lamp Module (123610 68G).
  • Added Z-Wave support for Philio Double Relay Module (PAN04).
  • Added Z-Wave support for Philio Motion Sensor (PSM02).
  • Added Z-Wave support for Vision Garage Door Tilt Sensor (ZG8101).
  • Added Z-Wave support for Vision Siren and Strobe module (ZM1601), including both configuration parameters.
  • Added Z-Wave support for additional variant of Digital Home Systems Motion Sensor (DHS-ZW-SNMT-01).
  • Added Z-Wave support for additional variant of Duwi Key Fob (ZME-KFOB).
  • Added Z-Wave support for additional variant of Fibaro Dimmer Switch (FGD211).
  • Added Z-Wave support for additional variant of FortrezZ I/O Module (MIMOlite).
  • Added additional configuration parameters for the Evolve LRM-AS dimmer switch.
  • Added "Reason" field to the "Email Log..." help menu item dialog to help us connect the log to your issue.
  • Improved scene trigger detection for Duwi Key Fob (ZME-KFOB).
  • Improved support for Philio Motion Sensor (PSM02).
  • Fixed bug that caused SQL Logger pluggin to fail to create device tables if device state names matched SQL keywords.
  • Fixed Main Window thermostat mode popup bug that would show a blank menu if active mode was one of the program modes.
  • Removed read-only variables from the list of available variables in all the set variable actions (destination lists only).
  • Increased the maximum width of the "Protocol" column in the Mac Client.
  • Enabled the Remote Display option for custom plugin devices.
  • Enabled display of custom devices, including their status, in Indigo Web Server built-in device lists. Note - custom devices will also show in Indigo Touch 1.7 (the current version) but it will only show the name (no status) - a future revision of Indigo Touch will add that capability.
