Indigo 6 v6.0.5 Released
Wed Nov 13, 2013 2:47 pm
6.0.5 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave support for TKBHome Appliance Module (TZ68E), Dual Button Relay Switch (TZ66D), and Relay Switch (TZ66S).
  • Added Z-Wave support for Leviton RZCS4-1LX button press scenes triggers.
  • Added Z-Wave support for Everspring Motion Sensor (SP103) tamper switch.
  • Improved Z-Wave state updating responsiveness for some Leviton controllers.
  • Improved handling of plugin launch failures (works around Mac OS X 10.9 problem).
  • Improved error messaging when speakers disappear from Airfoil.
  • Improved error recovery when a device disappears from Indigo which is present in a device group.
  • Improved error handling in the iTunes plugin when a bad packet is received.
  • Improved event logging suppressing for humidity and temperature changes.
  • Fixed several issues with adding devices and thermostat handling in the Vera Bridge plugin.
  • Fixed bug that would cause some Fibaro FGS221 modules to be recognized as FGS211 modules.
  • Fixed bug that would cause energy meter resets to not immediately update in the UI.
  • Fixed bug that would cause some Z-Wave devices to be disabled on server launch.
  • Fixed bug that could cause main window device list flame icon to show on some thermostats that don't supoort heat on/off states.
Developer API Changes:
  • Status column image is now selected based on the raw state value, not any passed in UI value.
