Indigo 6 v6.0.3 Released
Sun Oct 06, 2013 6:05 pm
6.0.3 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave triggers for thermostat modules: Main Mode Update, Cool/Heat Equipment State, Fan Mode Update, Fan Equipment State, Setpoint Update, Temperature Update, Humidity Update, Status Reply, Any Command
  • Added Z-Wave support for Digital Home Systems Temperature/Binary Sensor (iTemp).
  • Added Z-Wave support for Duwi battery powered Dimmer Switch (ZME-6443).
  • Added Z-Wave support for Everspring Smoke Alarm (SF812).
  • Added Z-Wave support for First Alert Smoke Alarm (ZSMOKE) and Smoke / Carbon Monoxide Alarm (ZCOMBO).
  • Added Z-Wave support for Remotec IR Thermostat Bridge (ZXT-120).
  • Added Z-Wave support for Vision Motion Sensor (ZP3102).
  • Added Z-Wave parameter "Dim control pulse length" UI to Fibaro Dimmer Switch (FGD211).
  • Added workaround to OS X speech manager problem that would cause speaking to stop working correctly.
  • Added support in sprinkler actions UI for scheduling up to 16 zones (previous max was 8).
  • Fixed bug that would cause a client UI error inside the Upload Settings dialog if a Trigger or Schedule had only numeric characters in its name.
  • Fixed bug that would cause "plugin does not define method actionControlDimmerRelay" error log if an AppleScript requested status of some plugin devices.
  • Fixed bug that would cause the WeatherSnoop plugins to fail to validate stations for 2.1.x.
  • Fixed bug that would cause the state column for 2.1.x WeatherSnoop stations to be blank.
  • Fixed bug in Vera Bridge plugin that would fail to add the batteryLevel state to existing devices that were converted to bridge devices.
  • Improved filtering of duplicate INSTEON commands sent by some battery powered modules.
Developer API Changes:
  • Plugin API version number has been incremented to v1.12.
  • Plugin API change: removed sprinkler device activeZoneIndex attribute and restored activeZone attribute. See API release notes for details.
  • Plugin API deprecation: indigo.sprinkler.turnOnZone(). Callers should now use the indigo.sprinkler.setActiveZone() method.
  • Plugin API addition: indigo.sprinkler.setActiveZone(), which is identical to the indigo.sprinkler.turnOnZone() method except setActiveZone()'s index argument is 1-based instead of 0-based (None or 0=all zones off, 1=zone 1, 2=zone 2, …).
  • Plugin API addition: indigo.server.waitUntilIdle() method which can be used to block script or plugin execution until the Indigo Server is idle.
Users browsing this forum: No registered users and 18 guests
