Indigo 6 v6.0.2 Released
Thu Sep 19, 2013 9:56 am
6.0.2 is now available for download.
In addition to the major 6.0 improvements this update includes:
  • Added Vera Bridge plugin - see the plugin documentation for details.
  • Added support for WeatherSnoop 3 weather station agents to the WeatherStation plugin.
  • Added Z-Wave triggers for dimmable modules: dim started, dim stopped, brighten started, brighten stopped.
  • Added Z-Wave support for Aeotec Single Button keyfob (DSA38).
  • Added Z-Wave support for battery operated Cooper Remote Switch (RF9500).
  • Added Z-Wave support for EUROtronic Thermostat (Stella Z).
  • Added Z-Wave support for Everspring Temperature/Humidity Sensor (ST814).
  • Added Z-Wave support for Everspring Illumination Sensor (ST815).
  • Added Z-Wave support for Express Controls EZMotion+ Multi Sensor (HSM100-S3).
  • Added Z-Wave support for Fibaro Leak Sensor (FGFS111).
  • Added Z-Wave support for FortrezZ I/O Module (MIMOlite).
  • Added Z-Wave support for FortrezZ Sirens (SSA1, SSA2, SSA3).
  • Added Z-Wave support for FortrezZ Water Valve (WV01).
  • Added Z-Wave support for Horstmann/Secure Radiator Thermostat (HRT4-ZW).
  • Added Z-Wave support for Horstmann/Secure 1 Channel Boiler Actuator (SSR303 / ASR-ZW).
  • Added Z-Wave support for Horstmann/Secure 2 Channel Boiler Actuator (SSR302).
  • Added Z-Wave support for NorthQ Power Reader (NQ-92021).
  • Added Z-Wave support for Wintop / Digital Home System iDoorSensor.
  • Added mulitple power/energy UI settings for the Fibaro Wall Plug Relay (FGWP011).
  • Added support for INSTEON Ballast Dimmer (2475DA2).
  • Added capability to hide battery level broadcasts for Aeotec Home Energy Monitor (DSB09104).
  • Improved automatic reading of power/energy from Z-Wave relay and dimmer modules after their states are changed.
  • Improved the interface in the device control area when a device updates frequently and has custom states.
  • Improved error reporting for plugin dynamic lists that use invalid ID strings.
  • Modified INSTEON Micro Open/Close device to show dimmer UI for precise open/close positioning (Re-Sync the device to update the UI shown).
  • Modified Variable Window so that changes are now committed when the window becomes inactive (thus avoiding a potential Indigo Client crash/hang).
  • Removed the Action Collection from the plugins list in the Preferences window.
  • Fixed bug that prevented Z-Wave Everspring door/window sensor (SM103) from working.
  • Fixed bug that could cause the dimmer ramp rate popup to not update in the INSTEON Link Editor dialog.
  • Fixed bug that could cause tiles in the device control area to shrink.
  • Fixed bug that could cause plugin device states to not be updated after closing device configuration dialog.
