Indigo 6 Beta 10 Released
Thu Jun 13, 2013 10:12 pm
6.0 Beta 10 is now available for download.
Important: this version includes some Z-Wave related enhancements. Because of the nature of some of these changes, you might have to re-sync (via the device dialog) some of your modules. The devices that need to be re-synced will be shown in the Event Log, and communication with them will be disabled in Indigo until they are re-synced.
In addition to the major 6.0 improvements this update includes:
  • Added Z-Wave support for 2GIG Thermostat (CT100). For full functionality Indigo requires the thermostat to be AC (not battery) powered.
  • Added Z-Wave support for Honeywell Z-Wave Thermostat (TH8320ZW1000).
  • Added Z-Wave support for reading energy information (watts and kilowatt hours) from Aeotec Smart Energy Switch (DSC06106) and Illuminator (DSC08101).
  • Modified INSTEON device syncing to allow syncing of modules that specify a bad firmware version (second attempt at this fix).
  • Fixed bug when coloring selected text in columns in the device table.
  • Fixed bug that would sometimes allow the device list side of the split view in the main window to become too small.
  • Fixed bug that prevented 1-Wire temperature sensor connected to Fibaro Door/Window Sensors (FGK101) from displaying.
  • Timers Plugin: fixed stack trace that would sometimes appear in the event log when a timer expired.
Developer API Changes:
  • Plugin API version number has been incremented to v1.9.
  • Plugin API addition: Added energyCurLevel and energyAccumTotal attributes to device instances to return the current Watts and Kilowatt hours energy usage information for devices that support energy reporting. Devices that do not support energy reporting will return None objects.
