New Error
Thu Jan 11, 2024 5:08 pm
Different Computers offline
New Error
Suddenly seeing this.
 uniFiAP Error
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 449, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 444, in _make_request
    httplib_response = conn.getresponse()
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 1374, in getresponse
    response.begin()
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 318, in begin
    version, status, reason = self._read_status()
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/http/client.py", line 279, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 705, in readinto
    return self._sock.recv_into(b)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ssl.py", line 1273, in recv_into
    return self.read(nbytes, buffer)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ssl.py", line 1129, in read
    return self._sslobj.read(len, buffer)
TimeoutError: The read operation timed out
During handling of the above exception, another exception occurred:
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/adapters.py", line 440, in send
    resp = conn.urlopen(
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 785, in urlopen
    retries = retries.increment(
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/util/retry.py", line 550, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/packages/six.py", line 770, in reraise
    raise value
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 703, in urlopen
    httplib_response = self._make_request(
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 451, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/urllib3/connectionpool.py", line 340, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='192.168.0.1', port=443): Read timed out. (read timeout=10.0)
  File "plugin.py", line 5337, in executeCMDOnController
    elif cmdType == "post":   resp = self.unifiControllerSession.post(url,    json=dataSEND,      cookies=cookies, headers=headers, allow_redirects=False, verify=False, timeout=self.requestTimeout, stream=setStream)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 577, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 529, in request
    resp = self.send(prep, **send_kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/sessions.py", line 645, in send
    r = adapter.send(request, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/requests/adapters.py", line 532, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='192.168.0.1', port=443): Read timed out. (read timeout=10.0)
My UDM is suspect, but I can log in to it any other way no problem. Though I am seeing some slow response from the Unifi web console.
Sat Jan 13, 2024 2:23 am
Re: New Error
I have a new version that reduces the extensive log dump and only writes a message if it fails after 3 attempts.
But yes something changed on the UniFi side. I also see more timeouts
I will post the new version today.
Wed Jan 31, 2024 2:48 pm
Re: New Error
This just popped up and I haven't seen this before. Maybe the new version is condensing from some larger error I used to see?
   uniFiAP Error                   error:>> url:https://1REDACTEDIP:443/proxy/network/api/s/default/cmd/stamgr, resp:{"meta":{"rc":"error","mac":"00:55:da:5d:6f:ca","msg":"api.err.UnknownStation"},"data":[]}
Wed Jan 31, 2024 2:55 pm
Re: New Error
If this happens once or twice a day no problem. As long as it does not show up on a regular basis. Sometimes the communication is interrupted.
And yes I have reduced the „error memory dump“ to much smaller log messages that give a little bit more condensed info.
Wed Jan 31, 2024 3:17 pm
Re: New Error
Thanks! I'll keep an eye on it, but I bet it's fine.
