New Error with 2022.40.382
Wed Aug 24, 2022 2:25 pm
Never seen this before, though it MIGHT be due to the whole M1 mini seemingly choking for a minute and becoming unresponsive. I just upgraded from 2021 and to the M1 mini yesterday.
uniFiAP Error                   Expecting ',' delimiter: line 2424 column 2 (char 33712); line#,Module,Statement:(353, 'raw_decode', 'obj, end = self.scan_once(s, idx)')
   uniFiAP                         checkAndPrepDict JSON len:65923; _be_more_precise": true,"child_devices_count": 2,"child_virtual_devices_count": 3,"created_at": "201...
...  rxBytes": 35076,xxxThisIsTheEndTokenxxx3
   uniFiAP                         .... in receiving DICTs for UDdict-192.168.0.1;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.uniFiAP/plugin.log
log says
2022-08-24 16:16:04 testServerIfOK: =========== known prompts:
{'192.168.0.123': '1# ', '192.168.0.1': '# '}
2022-08-24 16:16:04 getMessage, error reading dict >UDdict-192.168.0.1<, not complete? len(data)69161, endTokenPos:69191; error:Expecting ',' delimiter: line 4271 column 2 (char 69161) ---- retrying
2022-08-24 16:16:08.346   ERROR          Plugin.checkAndPrepDict          Expecting ',' delimiter: line 2424 column 2 (char 33712); line#,Module,Statement:(353, 'raw_decode', 'obj, end = self.scan_once(s, idx)')
2022-08-24 16:16:19 testServerIfOK: =========== 192.168.0.1; prompt not found or reset by restart;  old:'\# ', new candidate:'
2022-08-24 16:16:19 testServerIfOK: =========== for 192.168.0.1  ssh response, setting promp to:'# ' using last 2 chars in ...****************
2022-08-24 16:16:19 testServerIfOK: =========== known prompts:
2022-08-24 16:16:20 checkAndPrepDict JSON len:65923; _be_more_precise": true,"child_devices_count": 2,"child_virtual_devices_count": 3,"created_at": "201...
2022-08-24 16:16:20 .... in receiving DICTs for UDdict-192.168.0.1;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.uniFiAP/plugin.log
2022-08-24 16:16:20 .... ping test:   ok
2022-08-24 16:16:20 .... ssh test:    ok
2022-08-24 16:16:20 .... uid/passwd:>('root', 'hBe-yzs-f7n-FTq')<
2022-08-24 16:16:28 getMessages: relaunching dictLoop.exp / UDdict / 192.168.0.1: code:0; timeSinceLastRestart 233 > forcedRestart:999999999 [sec]  ;  without message:136.3[sec], limitforRestart:135.0[sec], restartCount:0,  len(msg):62067; lastMSG:: 6601818,"txPackets": 94086},{"app": 15,"cat": 13,"rxBytes": 35076,xxxThisIsTheEndTokenxxx3<<
2022-08-24 16:16:38 testServerIfOK: =========== 192.168.0.1; prompt not found or reset by restart;  old:'\# ', new candidate:'
2022-08-24 16:16:38 testServerIfOK: =========== for 192.168.0.1  ssh response, setting promp to:'# ' using last 2 chars in ...****************
Thu Aug 25, 2022 2:40 am
Re: New Error with 2022.40.382
that looks like the response from the unifi device is not complete.
it might happen once or twice, but if it repeats SOMETHING is wrong.
eg here
the json is not complete the "end token" = ",xxxThisIsTheEndTokenxxx" comes in the middle of the json.
that is all I can say from that.
Fri Aug 26, 2022 8:22 am
Thanks Karl.
Haven't seen it again, so I'll assume it was new setup glitches for now.
