no os and / port found
Thu Jun 02, 2022 5:21 pm
Different Computers offline
   uniFiAP Warning                 getunifiOSAndPort bad return from unifi controller 192.168.0.1, no os and / port found, tried ports:[u'443', u'8443']
This is new. happens on a restart. Also happens regularly after starting the plugin. How do I fix it? The plugin seems to be working otherwise, so this error is puzzling.
Fri Jun 03, 2022 2:16 am
Re: no os and / port found
Q:
are you using the latest V? (7.40.397)
then try:
in config:
- set controller prot to 443
- set curls or python request to python requests
Fri Jun 03, 2022 7:35 pm
I am using 7.40.397.
port was default, now set to 443.
Curls now changed to python requests. Seems to come back up and start functioning (because Unifi devices show statuses)....
sits for a while at "initialized ... looping"...
Been a couple of minutes now and my only log entry is
uniFiAP                         comsumeLogData        excessive time consumed: 12.0[secs]; 192.168.0.123   ; len:2,  lines:[u'Fri Jun  3 21:33:32 2022 daemon.info stahtd: stahtd[1265]: [STA-TRACKER].stahtd_dump_event(): {"a
So maybe that fixed the issue? Thanks!
Sat Jun 04, 2022 1:35 pm
Yes the new UniFi version does not reply to the port test as before.
So hardwiring the port solved that
