Error as soon as I start plugin
Wed May 25, 2022 5:30 pm
hensed offline
Hello! I'm hoping someone here can help me figure out what's going on. when I start the unifi plugin I immediately get these errors:
 Starting plugin "uniFiAP 7.39.370" (pid 17037)
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         indigo                  /Library/Application Support/Perceptive Automation/
   uniFiAP                         installFolder           /Library/Application Support/Perceptive Automation/Indigo 2021.2/
   uniFiAP                         plugin.py               /Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
   uniFiAP                         Plugin params           /Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         check                   /Library/Application Support/Perceptive Automation/Indigo 2021.2/Logs/com.karlwachs.uniFiAP/plugin.log  <<<<    for detailed logging
   uniFiAP                         Plugin short Name       UniFi
   uniFiAP                         my PID                  17037
   uniFiAP                         set params for indigo V 2021.2
   Started plugin "uniFiAP 7.39.370"
   uniFiAP                         testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   uniFiAP                         myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 2021.2/Logs/com.karlwachs.uniFiAP/plugin.log;  debugLevel= []
   uniFiAP                         MAP2Vendor initializing
   uniFiAP                         MAP2Vendor I making directory:/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/mac2Vendor/
   uniFiAP Error                   Error in plugin execution startup:
  File "plugin.py", line 487, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/MAC2Vendor.py", line 38, in __init__
OSError: (2, 'No such file or directory', '/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/mac2Vendor/')
   uniFiAP Error                   in Line 909 has error=[Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/dataVersion'
   uniFiAP Error                   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 6047, in runConcurrentThread
  File "plugin.py", line 5586, in fixBeforeRunConcurrentThread
AttributeError: 'Plugin' object has no attribute 'cameraSystem'
   uniFiAP Error                   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Am I even on the right path to getting this figured out?
Thu May 26, 2022 12:29 am
Re: Error as soon as I start plugin
please upgrade to the latest version https://www.indigodomo.com/pluginstore/73/
or open terminal and enter
echo "" > ''/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/mac2Vendor/'
with the " and '
But i strongly suggest to upgrade
Fri May 27, 2022 6:18 pm
hensed offline
Thank you I upgraded, but was still getting the error, but I saw the directory it was trying to create so I just created it. Then I reloaded the plugin and it worked. No devices are listed in the unifi folders so now I'm figuring that out, but this is the furthest I've gotten. Thanks for pointing me in the right direction!
with the " and '
