UnifiAP Errors @ line 12602
Sat May 21, 2022 6:33 am
bbbullock offline
Getting a lot of errors from my UnifiAP plugin. Are these of concern? And if so, what do I need to do to correct?
May 21, 2022 at 7:27:35 AM
uniFiAP Error 'global name 'loclocalCopyal' is not defined'
addToStatesUpdateList @line 12602: 'loclocalCopyal[devId][key] = {}'
uniFiAP comsumeDictData excessive time consumed: 39.6[secs]; 192.168.1.16 - 1-APdict len:68, item:{u'model': u'U7PG2', u'wifi_caps': 22986453, u'countrycode_table': [840, 124, 630], u'ip': u'192.168
uniFiAP comsumeDictData Total excessive time consumed: 41.3[secs]; 192.168.1.208 - 4-APdict; items: 3 len:68, item:{u'model': u'U7MP', u'wifi_caps': 22986453, u'countrycode_table': [840, 124, 630], u'ip': u'192.168.
uniFiAP Warning getunifiOSAndPort bad return from unifi controller 192.168.1.17, no os and / port found, tried ports:[u'8443', u'443', u'8443']
May 21, 2022 at 7:28:05 AM
uniFiAP comsumeLogData excessive time consumed: 14.0[secs]; 192.168.1.16 ; len:2, lines:[u'Sat May 21 07:27:50 2022 daemon.notice /usr/sbin/lbd[2476]: 07.27.50.439954 LBDR wlanif debug:
uniFiAP comsumeDictData excessive time consumed: 10.1[secs]; 192.168.1.12 - 0-SWdict len:68, item:{u'root_switch': u'84:e0:58:27:11:1f', u'model': u'US24P250', u'version': u'6.2.14.13855', u'ip': u'
uniFiAP comsumeDictData Total excessive time consumed: 10.1[secs]; 192.168.1.12 - 0-SWdict; items: 1 len:68, item:{u'root_switch': u'84:e0:58:27:11:1f', u'model': u'US24P250', u'version': u'6.2.14.13855', u'ip': u'
uniFiAP comsumeLogData Total excessive time consumed: 14.0[secs]; 192.168.1.76 ; items:27 len:2, lines:[u'Sat May 21 07:28:03 2022 daemon.info stahtd: stahtd[2478]: [STA-TRACKER].stahtd_dump_event(): {"m
Indigo Cocoa client authenticated (192.168.1.23)
May 21, 2022 at 7:28:51 AM
Sat May 21, 2022 7:35 am
Re: UnifiAP Errors @ line 12602
That’s a copy/paste bug by the author by the looks of it :-)
Sun May 22, 2022 6:15 am
yes, that was a copy into the middle of "local" and line was not executed that often...
That bug should have been fixed in the latest release @bbbuldog, please check https://www.indigodomo.com/pluginstore/73/
Sun May 22, 2022 3:21 pm
bbbullock offline
Updated to v.379 and it cleared up the errors.
Tue May 31, 2022 7:43 pm
Different Computers offline
I'm running .379 and still getting
   uniFiAP Error                   global name 'item' is not defined; line#,Module,Statement:(12794, 'unsetBlockAccess', 'tempQueue.put(item)')
constantly. Running 2021.2 I'm a bit confused by "only supports 2022.1 and earlier". I mean, isn't everything earlier than 2022.1?
Fri Jun 03, 2022 2:21 am
my line shows:
tempQueue.put(blockingPGM)
yours is:
tempQueue.put(item)
there must be something wrong with the V numbers.. I will repost (increase the v number)
Kark
Fri Jun 03, 2022 2:41 am
just published .380 that should fix it .
