"Wrong ip/password of system down" error
Posted: Sun Oct 31, 2021 11:01 pm
Added two new switches to my stack - USW Enterprise 8 PoEs.
I can successfully ssh in to them with the same user/password as all my other switches. But these two both just repeat the login failure message over and over:
I turned on debugging level 20, and clicked the 'show debug...' buttons for those two switches but don't have access to the logs at the minute (I'm remote)
The ssh intro page for these devices looks like:
Which is essentially the same as the splash screen on some of the older gen devices that work with the plugin. The only thing I see that is immediately different is the new one is missing hte datetime from between teh parenthesis on the BusyBox line, and it is a slightly newer version (1.25 vs 1.23.2)
- Code: Select all
uniFiAP Error getMessages: (1 - test connect) error for SWdict, ip#: nn.mm.xx.yy, prompt:'not defined'; wrong ip/ password or system down or ssh timed out or ..?
Oct 31, 2021 at 9:52:04 PM
uniFiAP Error getMessages: (1 - test connect) error for SWdict, ip#: nn.mm.xx.zz, prompt:'not defined'; wrong ip/ password or system down or ssh timed out or ..?
- Code: Select all
BusyBox v1.25.1 () built-in shell (ash)
___ ___ .__________.__
| | |____ |__\_ ____/__|
| | / \| || __) | | (c) 2010-2021
| | | | \ || \ | | Ubiquiti Networks, Inc.
|______|___| /__||__/ |__|
|_/ https://www.ui.com/
Welcome to UniFi USW-Enterprise-8-PoE!
Office-US.5.64.8# help
UniFi Command Line Interface - Ubiquiti Networks
info display device information
set-default restore to factory default
set-inform <inform_url> attempt inform URL (e.g. set-inform http://192.168.0.8:8080/inform)
upgrade <firmware_url> upgrade firmware (e.g. upgrade http://192.168.0.8/unifi_fw.bin)
fwupdate --url <firmware_url|firmware_name> [--dl-only] [--md5sum <sum_of_fw>]
[--keep-firmware] [--keep-running] [--reboot-sys]
new firmware update command
reboot reboot the device
Office-US.5.64.8#
