Connection error to controller
Fri Oct 29, 2021 8:03 am
macpro offline
Lately I'm seeing lot's of connection errors in my Indigo logfile.
They appear a couple of times per minute.
   uniFiAP Error                    Connection error: >>A.B.C.D<<
{"meta":{"rc":"error","msg":"api.err.InvalidObject"},"data":[]}
A.B.C.D is the IP address for my UniFi controller on macOS.
Any idea why this is happening?
Mon Nov 01, 2021 1:25 pm
macpro offline
Solved! Connection error to controller
I've found the cause of these errors.
I enabled the Protect option for the camera's. But my setup is special. The camera's are connected to a CloudKey Gen 2+, but my UniFi Controller runs on a Mac.
The plugin assumes Protect runs on the same device as the Controller.
It even mentions this in the fine print, but I read that only after I discovered this.
So in the end it was just a case of PEBKAC.
Wed Nov 03, 2021 1:11 am
Re: Connection error to controller
Allowing those to run on 2 machines is on my list. But likely not this year.
