consumeDictData error
Sat May 08, 2021 11:59 pm
MarcoGT offline
Hi Karl,
since yesterday I have this error and Indigo log is now full.
Plugin restart did not help
V.365
   uniFiAP                         comsumeDictData   excessive time consumed:3.1; 192.168.2.128-1-APdict len:62,  item:{u'wifi_caps': 573429, u'countrycode_table': [], u'ip': u'192.168.2.128', u'uptime': 351139, u'if_ta
Sun May 09, 2021 6:59 am
Re: consumeDictData error
This is not an ERROR message.
It indicates that your indigo server is busy.
Try restarting the indigo server. - not the indigo client.
Wed May 12, 2021 12:03 pm
MarcoGT offline
I restarted the server, but the error is still there
Thu May 13, 2021 9:39 am
MacroGT:
added option in config to set the time after which it will print a warning to the logfile.
v ...370
"added warning levels for excessive time used to consume data for unifi devices
set in config at bottom in EXPERT section"
set to 10 / 10 secs
Fri May 14, 2021 2:54 am
MarcoGT offline
I think it is not published on the Plugin Store, isn't it?
Fri May 14, 2021 5:25 am
Screen Shot 2021-05-14 at 06.24.34.png (26.51 KiB) Viewed 2760 times
Sun May 16, 2021 7:36 pm
@marcogt: did you find it ?
Fri May 21, 2021 6:56 am
MarcoGT offline
Yes, now log is not flooded
Fri Jun 10, 2022 9:07 pm
DPattee offline
This message doesn't seem to be controllable by the checkboxes in the 'debug' section in v 380. Is there a way to suppress them?
I already have the two 'max time for excessive...' boxes set to 20 seconds, but I had to disable the plugin because it was flooding my log with 4 lines every (minute and a half-ish). I don't really care that some response took 22.0 seconds and another took 21.8 seconds since there isn't anything that I can actually do about that... My indigo server's macmini is only running at 10-15% CPU and still has 8 of its 16 gigs of ram free, so it isn't particularly overloaded
