All fields red after new password
Thu Apr 08, 2021 12:49 am
MarcoGT offline
I have modified the web password (and enable 2FA) but unfortunately when changing the password in the plugin config, all the filled fields are marked as red.
Any hints?
Marco
Thu Apr 08, 2021 9:45 pm
2fa = no access to UniFi from the plugin.
Sorry.
So what you do you do change passwords in config and you get everything red?
Please check plugin.log file.
Thu Apr 08, 2021 11:58 pm
MarcoGT offline
Re: All fields red after new password
But in an older post of you, I read that 2fa should not impact on accessing to UniFi from plugin because is local, or am I wrong?
I will check the logs, thanks
EDIT: just noticed that the problem with the red fields happens when I try to add a new AP
Fri Apr 09, 2021 1:29 am
if you use 2fa locally then it will not work.
if it does not impact logging on to the controller: then not a problem.
I just added an extra AP in config: no error message.
I need to know what you did exactly: could you send screen shot of config (the ap part) and the plugin.log file around the time when you click save
Fri Apr 09, 2021 2:47 am
MarcoGT offline
The problem was the field "get camera updates (dev state) every x minutes"
I think the field is new within the last release and was empty.
But the problem is that only that field shall be marked in red, not all fields.
But everything fine now.
Marco
Fri Apr 09, 2021 8:09 am
what exactly was the error message in the logfile ? something with can not be converted to float?
[EDIT]
in the next release I will add a message field that shows the error
