USW Flex Mini
Tue Apr 06, 2021 10:47 am
neilk offline
USW Flex Mini
Hi Karl,
Not an issue but I just bought one of these to replace an US8 that had an intermittment hardware fault. It seems they do not support SSH so you get the following error
uniFiAP Error                   testServerIf ssh connection to server failed, cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' 'user' 'password' 192.168.1.192
   uniFiAP Error                   in Line 7685 has error=u'192.168.1.192'
It looks like they have limited functionality compared to the fully fledged devices but small and neat for the location I needed. Not sure if they do support anything that could be useful for your plugin, mainly reporting so other people are aware.
Neil
Tue Apr 06, 2021 1:48 pm
Re: USW Flex Mini
Try:
Open terminal
ssh yourunixuserid&ipofcamera
Enter Unix password
If that works something else is wrong
I have almost all types of UniFi cameras
The $27 instant. The $80 flex, the 3g dome, the 3g bullet and the 4g bullet w zoom.
They all work fine.
Tue Apr 06, 2021 1:53 pm
neilk offline
Re: USW Flex Mini
Tue Apr 06, 2021 1:57 pm
Re: USW Flex Mini
The controller communicates with all devices through ssh and other means. It should work.
And the error message indicates something wrong w the Ip number not in the tables (dict) within the plugin.
So could you check if you can do ssh
There are switches w 4 5 6 7 8 10 11 14 16 26 52 ... ports defined in the plugin.
[EDIT]
is a format error, the prompt for that device is not set up yet.
that in turn means the connect did not work = could not log in
the prompt is found in testServerIfOK
also could you check the file /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
for more info?
Karl.
Wed Apr 07, 2021 2:17 pm
neilk offline
Re: USW Flex Mini
Hi Karl,
They definitely don't support ssh
Here is the relevant part of the plugin log
2021-04-07 21:10:31.914   ERROR          Plugin.checkIfRestartNeeded      in Line 7685 has error=u'192.168.1.192'
07 21:10:45 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.1:  timeSinceLastRestart 135 > forcedRestart:999999999 [sec]  ;  without message:135.1[sec], limitforRestart:135.0[sec], restartCount:0,  len(msg):290; lastMSG:ree to be bound by its terms.neilk@192.168.1.1's password: Permission denied, please try again.<<
07 21:10:48 getMessages: relaunching execLog.exp / APtail / 192.168.1.1:  timeSinceLastRestart 136 > forcedRestart:999999999 [sec]  ;  without message:135.3[sec], limitforRestart:135.0[sec], restartCount:0,  len(msg):38; lastMSG:Permission denied, please try again.<<
07 21:10:48 getMessages: launching listener for: SWdict / 192.168.1.192
2021-04-07 21:10:49.102   ERROR          Plugin.testServerIfOK            testServerIf ssh connection to server failed, cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' 'user' 'password' 192.168.1.192
07 21:10:49 testServerIfOK: ===========192.168.1.192  ssh response, tags [u'welcome', u'unifi', u'debian', u'edge', u'busybox', u'ubiquiti', u'ubnt', u'login'] not found : ==>
spawn ssh neilk@192.168.1.192
ssh_exchange_identification: Connection closed by remote host
Wed Apr 07, 2021 3:27 pm
RogueProeliator offline
Re: USW Flex Mini
FWIW, this was in the Mini documentation (this is the footnote on multiple items which is why their list of not supported are not all related techs):
* USW-Flex-Mini uses port-based VLANs only and does
not support SSH, STP (forwarding only), 802.1X, DNS
suffix, or experience in the controller.
Wed Apr 07, 2021 4:22 pm
Re: USW Flex Mini
Then I guess you need to remove that switch from config.
Thinking about how to get it Into the plugin. Nice challenge
Thu Apr 08, 2021 1:44 am
neilk offline
Re: USW Flex Mini
Karl,
No panic or expectations for me, it was just to let you and others know who may expect the difference. I don’t need any Functionality for that one. I do know you like a challenge though!
Neil
