New errors after Indigo 7.5 upgrade
Thu Mar 04, 2021 10:55 am
Different Computers offline
explanatory note: the SSID of my wifi network is "Not Found". Literally that.
[ uniFiAP Error in Line 4561 has error=No JSON object could be decoded
uniFiAP Error executeCMDOnController has error, os:unifi_os; cmdType:post, url:https://192.168.0.1:443/proxy/network/api/s/default/cmd/stamgr
uniFiAP Error executeCMDOnController retCode:404, resp: Not Found
uniFiAP Error in Line 4533 has error='str' object has no attribute 'cookies' Connectionquote][/quote]
Thu Mar 04, 2021 10:28 pm
Re: New errors after Indigo 7.5 upgrade
Which UniFi plugin v are you using ?
Fri Mar 05, 2021 8:52 am
7.34.322, but after reading that question I'm upgrading to the latest 7.37.441 right now. I'll let you know if I see any more errors.
Sat Mar 06, 2021 4:03 am
Turribeach offline
I am getting similar errors too, can't remember when they started, could be with Indigo 7.5. I just upgraded to plugin v7.37.341 and they still show up. This is what I get:
   uniFiAP Error                   in Line 7608 has error='module' object has no attribute 'exc_traceback'
   uniFiAP Warning                 checkAndPrepDict: error for APdict - 192.168.1.124
I thought this might be something on my APs since if I reboot the AP in question the error dissapears but eventually it comes back again. Any ideas?
Sat Mar 06, 2021 4:29 am
@Turribeach:
this error is in a complete different area: >>Line 7608 has error='module' object has no attribute 'exc_traceback'<< than the http error, one talks to the unifi controller through http, the other is talking to the wifi-ap through ssh
fixed in v .342 it is in an error the error section.
But the underlying issue is that the AP does not answer with a valid response.
How often do you get this error message?
And what is your MAC-OS version?
And you should get more messages in the plugin.log file, could you post that?
AND @ Different Computers:
what is the unifi controller version? 6.x or 5.x ?
Sun Mar 07, 2021 3:37 pm
Turribeach offline
>> I am now getting it all the time on all 3 APs. I just upgraded to the latest controller version (6.0.45-14358-1).
>> 10.14.6 (Mojave)
07 21:35:44 checkAndPrepDict: error for APdict - 192.168.1.117
07 21:35:44 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.117:  timeSinceLastRestart 22 > forcedRestart:999999999 [sec]  ;  without message:1615152943.8[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):84; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPLiving-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
07 21:35:58 getMessage, error reading dict >APdict-192.168.1.118<, not complete? len(data)0, endTokenPos:30; error:No JSON object could be decoded ---- retrying
07 21:36:01 getMessage, error reading dict >APdict-192.168.1.124<, not complete? len(data)0, endTokenPos:30; error:No JSON object could be decoded ---- retrying
07 21:36:06 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.118:  timeSinceLastRestart 31 > forcedRestart:999999999 [sec]  ;  without message:131.9[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):82; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPHall-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
07 21:36:10 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.124:  timeSinceLastRestart 31 > forcedRestart:999999999 [sec]  ;  without message:131.9[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):82; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPLoft-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
07 21:36:17 getMessage, error reading dict >APdict-192.168.1.117<, not complete? len(data)0, endTokenPos:32; error:No JSON object could be decoded ---- retrying
07 21:36:26 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.117:  timeSinceLastRestart 31 > forcedRestart:999999999 [sec]  ;  without message:131.9[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):84; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPLiving-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
2021-03-07 21:36:39.694   ERROR          Plugin.checkAndPrepDict          in Line 7608 has error='module' object has no attribute 'exc_traceback'
Sun Mar 07, 2021 5:06 pm
Turribeach offline
Different errors after the controller upgrade:
7 23:04:25 checkAndPrepDict: error for APdict - 192.168.1.118
07 23:04:25 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.118:  timeSinceLastRestart 21 > forcedRestart:999999999 [sec]  ;  without message:1615158264.2[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):82; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPHall-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
07 23:04:27 getMessage, error reading dict >APdict-192.168.1.124<, not complete? len(data)0, endTokenPos:30; error:No JSON object could be decoded ---- retrying
07 23:04:35 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.124:  timeSinceLastRestart 31 > forcedRestart:999999999 [sec]  ;  without message:131.9[sec], limitforRestart:130.0[sec], restartCount:0,  len(msg):82; lastMSG:mca-dump | sed -e 's/^ *//' UbiquitiAPLoft-BZ.v4.3.28# xxxThisIsTheEndTokenxxx1<<
07 23:04:40 testServerIfOK: ===========192.168.1.117  ssh response, tags [u'welcome', u'unifi', u'debian', u'edge', u'busybox', u'ubiquiti', u'ubnt', u'login'] not found : ==>
spawn ssh cdturri@192.168.1.117
2021-03-07 23:04:40.000   ERROR          Plugin.checkIfRestartNeeded      getMessages: (1 - test connect)  error for APtail, ip#: 192.168.1.117, prompt:'8# '; wrong ip/ password or system down or ssh timed out or ..?
2021-03-07 23:04:40.995   ERROR          Plugin.checkIfRestartNeeded      getMessages: (1 - test connect)  error for APdict, ip#: 192.168.1.117, prompt:'8# '; wrong ip/ password or system down or ssh timed out or ..?
2021-03-07 23:04:55.002   ERROR          Plugin.checkIfRestartNeeded      in Line 7425 has error=global name 'total' is not defined
2021-03-07 23:04:55.995   ERROR          Plugin.checkIfRestartNeeded      in Line 7425 has error=global name 'total' is not defined
07 23:04:58 getMessage, error reading dict >APdict-192.168.1.118<, not complete? len(data)0, endTokenPos:30; error:No JSON object could be decoded ---- retrying
Mon Mar 08, 2021 9:47 am
thats an error in the can not connect error handling.
will fix later today
and could you restart your AP(s) they sometimes seem to not answer, a reboot has fixed that for me
Mon Mar 08, 2021 10:30 am
Seeing this now, pretty regularly. Did not see it before. Using Controller 6.043
uniFiAP                         comsumeDictData   excessive time consumed:9.6; 192.168.1.1-0-UDdict len:41,  next:{u'ip': u'100.20.3.12', u'geo_info': {u'WAN': {u'city': u'Paradise', u'longitude': -7.2535, u'conti
   uniFiAP                         comsumeDictData T excessive time consumed:10.0; 192.168.1.1-0-UDdict len:41,  next:{u'ip': u'100.20.3.12', u'geo_info': {u'WAN': {u'city': u'Paradise', u'longitude': -8.2535, u'conti
IP and location obfuscated manually.
Mon Mar 08, 2021 10:51 am
Turribeach offline
Hi, I have restarted all APs and no more errors but they tend to come back eventually. I will keep an eye on the logs.
Mon Mar 08, 2021 8:30 pm
@Different Computers >> excessive time consumed: ...<< is a new warning message, was never shown before
it is an indication that the consumption of the data received takes longer than 3 seconds
that number was never measured before.
if this is an ongoing issue please check the cpu load on your indigo server.
Mon Mar 08, 2021 10:00 pm
A spot check right now shows 88% to 92% idle, less than 3 minutes after seeing that message in the log. I'll check again throughout the day tomorrow.
Sat Mar 20, 2021 10:34 am
Still seeing this regularly:
uniFiAP                         comsumeLogData    excessive time consumed:5.9[secs]; 192.168.0.2; len:2,  lines:[u'Sat Mar 20 12:26:42 2021 user.info : stahtd[1229]: [STA-TRACKER].stahtd_dump_event(): {"event_id"
   uniFiAP                         comsumeDictData   excessive time consumed:9.7; 192.168.0.1-0-UDdict len:41,  next:{u'ip': u'205.220.233.212', u'geo_info': {u'WAN': {u'city': u'Paradise', u'longitude': -8.2333, u'conti
   uniFiAP                         comsumeLogData  T excessive time consumed:6.3[secs]; 192.168.0.2; len:6,  lines:[u'Sat Mar 20 12:26:44 2021 daemon.info hostapd: ath0: STA 80:2a:a8:81:ed:9c DRIVER: Sead AUTH addr=
   uniFiAP                         comsumeDictData T excessive time consumed:10.1; 192.168.0.1-0-UDdict len:41,  next:{u'ip': u'20.20.23.2', u'geo_info': {u'WAN': {u'city': u'Paradise', u'longitude': -8.2333, u'conti
Line by line that's about my AP, my UDM, my AP again, and then my UDM and the WAN connection.
Running 7.37.341
On the plus side, everything seems to be working even with these warnings. CPU usage is solidly in the 25-30% range.
https://imgur.com/PksBzI6
Last edited by Different Computers on Sat Mar 20, 2021 10:39 am, edited 1 time in total.
Sat Mar 20, 2021 10:38 am
I added that check. It was not in the versions before
It simply states that it takes a
Long time to fill the indigo dev states.
That time is after receiving the messages
Take it as an indication that the indigo server is not idle.
The key q is how many do you get? Once a minute or some times
Sat Mar 20, 2021 10:42 am
Looking just at the last little bit of time:
12:40
12:33
12:29
12:57
12:14
12:08
11:57
11:27
