Controller on Mac, port 443 in use for something else
Mon Feb 15, 2021 6:19 am
macpro offline
I'm running the UniFi controller on a Mac where I also run Profile Manager.
The UniFi controller uses port 8443. Profile Manager uses port 443.
The UniFi plugin tries to connect to port 443 first and then fails because it doesn't get the answer it expects.
   uniFiAP Error                   Connection: in Line 4744 has error=No JSON object could be decoded
   uniFiAP Error                   UNIFI executeCMDOnController error no json object: (wrong UID/passwd, ip number?ip.ip.ip.ip) ...>><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /api/auth/login was not found on this server.</p>
</body></html>
Please add an option to the config to specifiy the port number that the plugin will use to connect to the controller.
I'm running the latest version: 7.36.324
Mon Feb 15, 2021 8:05 am
Re: Controller on Mac, port 443 in use for something else
I just removed that option to automate the config
Let me think about it.
when you upgrade the controller to v 6 you will have 2 systems that use 443 on your mac.
Then it will break.
Mon Feb 15, 2021 9:01 am
That's why I run the controller in Docker so I can remap the ports as needed.
Mon Feb 15, 2021 9:18 am
macpro offline
Then it will break.
It will not. The UniFi controller does not use port 443. (I’m already on 6.0.45.)
And if it would, you can always change the port numbers in the system.properties file.
That’s another reason why it would be better to let the port number be a configurable item.
Mon Feb 15, 2021 12:18 pm
With the new version it is.
It you don’t set anything it will try 443 and 8443. That should cover 95% of configs
Mon Feb 15, 2021 3:23 pm
macpro offline
But why use port 443? The default port is 8443. The UniFi controller does not use port 443.
See https://help.ui.com/hc/en-us/articles/2 ... Ports-Used for a list of ports.
Mon Feb 15, 2021 3:46 pm
And 443 is the default HTTPS port, which will be in use if the machine is running a web server.
Mon Feb 15, 2021 8:10 pm
for the controller w Unifi hardware:
the older version (5.x) ran on 8443, the new versions w info hardware all use 443
it might be that the Mac / unix version still runs on 8443
ps I am in a hotel now, power at home went out, not clear when it will come back.
dallas downtown is dark
we are in the hotel - no TV, no WiFi, no food, and manual check in = they wrote my cc info on a piece of paper and it took 2 hours to check.. and they are sold out , - all hotels in dallas are sold out
Tue Feb 16, 2021 12:34 am
macpro offline
That's new to me. Didn't know that.
If you want to stick to the auto-config, may I suggest the following?
Connect to 443 and verify if it works. If it does but you don't get the reply you're expecting, move to the next port: 8443. Try the connection again.
But to be honest, I think it is not a good design decision to let users not enter the port they are using.
They might have good reasons to use other ports.
Tue Feb 16, 2021 2:27 am
In the new version you can set it. If you don’t set it it will try 443 then &443
Tue Feb 16, 2021 1:20 pm
macpro offline
Thanks for the quick fix. Upgraded and it’s working again.
[nag]
There’s a typo in the description for the port parameter. “ahve” instead of “have”.
[/nag]
Tue Feb 16, 2021 2:01 pm
Stay safe and (hopefully) warm, Karl. So far we've lucked out in my sub-division and still have power, but one major street over they've been our for 36+ hours now.
Tue Feb 16, 2021 2:34 pm
The hotel lost power too. We drove home and 10 minutes after we arrived power came back. And one of the water pipes / faucets is frozen. Hope it will not burst when it thaws.
But have ice on the pool.
Tue Feb 16, 2021 4:06 pm
[nag]
[/nag]
Ahve and teh are the secret passwords
