getunifiOSAndPort bad return from unifi controller...
Tue Jan 26, 2021 10:01 pm
mundmc offline
Hi Karl, J
Thanks for all of your work! Just updated to 7.34.215 (I forget from what but it's been at least 4 months or so).
Now my event log is flooded with the last message below (it is referencing the port on which my Gen 1 Cloud Key is located):
Jan 26, 2021 at 10:50:13 PM
   Enabling plugin "uniFiAP 7.34.315"
   Starting plugin "uniFiAP 7.34.315" (pid 24820)
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         indigo                  /Library/Application Support/Perceptive Automation/
   uniFiAP                         installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.5/
   uniFiAP                         plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
   uniFiAP                         Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         check                   /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log  <<<<    for detailed logging
   uniFiAP                         Plugin short Name       UniFi
   uniFiAP                         my PID                  24820
   uniFiAP                         set params for indigo V 7.5
   Started plugin "uniFiAP 7.34.315"
   uniFiAP                         testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   uniFiAP                         myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log;  debugLevel= []
   uniFiAP                         MAP2Vendor initializing
   uniFiAP                         MAP2Vendor initializing  finished, read from mac2Vendor.json file
   uniFiAP Warning                 getunifiOSAndPort bad return from unifi controller 192.168.1.45, no os and / port found, tried ports:['8443', '443']
   Error (client)                  timeout waiting for plugin response from com.karlwachs.uniFiAP for request UiGetValues1
   Error (client)                  timeout waiting for plugin response from com.karlwachs.uniFiAP for request CallPluginFunc
   Error (client)                  runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Thoughts?
Wed Jan 27, 2021 7:36 am
Re: getunifiOSAndPort bad return from unifi controller...
could you upgrade to v .316?
It seems that the last upload had a corrupt pluginconfig.xml file, no clue how that happened
Sat Jan 30, 2021 6:38 pm
mundmc offline
Sorry if I'm dense, but when you type v.316, I'm kinda in the weeds with finding it.
https://www.indigodomo.com/pluginstore/13/
Above doesn't show it
https://www.dropbox.com/s/5dmpsf5ipu60b ... 2.zip?dl=0
Above is a higher version number but Indigo asks if I want to downgrade.
Thanks for clarifying, I am guessing this might have been a typo.
Sun Jan 31, 2021 12:35 pm
sorry for being cryptic post.
the latest "official" version is always in the plugin store https://www.indigodomo.com/pluginstore/73
During development I post intermediate versions on GitHub.
so gihub v >= indigo plugin store v
Indigo checks only against the plugin store version, so if you have downloaded a newer version from GitHub, you might get a message from indigo that the versions are higher/lower
Sat Mar 19, 2022 3:10 pm
dnomode offline
Hello Karl,
I'm getting the following warning. Any ideas?
I'm on:
Mac 10.13.6
Indigo 2021.2
Plugin 7.39.373
Unifi OS 2.3.15
Unifi Network 7.0.23
Thanks for the help.
Ed
Mar 19, 2022 at 5:01:19 PM
   uniFiAP Warning                 getunifiOSAndPort bad return from unifi controller 192.168.1.10, no os and / port found, tried ports:[u'443', u'8443']
   uniFiAP                         MAP2Vendor initializing  still waiting for download
Sun Mar 20, 2022 12:26 pm
the plugin tries to download mac# to vendor tables once very xx days
that site might not be reachable sometimes.
it should not create any issues beside these anoying messages
Mon Mar 21, 2022 7:50 am
dnomode offline
Hey Karl,
Thanks for the reply. I copied to much stuff. I was actually just concerned with this warning. Sorry
What you think?
