UNIFI user ids and password
Wed Jun 01, 2022 7:54 am
MartyS offline
Re: UNIFI user ids and password
kw123 wrote:
to help me understand, which part did not exist?
... Preferences/Plugins/com.karlwachs.uniFiAP/
or
... Preferences/Plugins/com.karlwachs.uniFiAP/mac2Vendor
Indigo 2022.1 with the plugin V7.40.379 loaded but not yet configured:
As a datapoint, your top-level path didn't get created. Maybe it takes setting something specific in the config to trigger the path creation? Created the top-level path and all the Indigo log errors went away. The mac2Vendor path was created automatically.
I'm looking forward to trying this plugin. My controller is running in a Docker container but that shouldn't matter I would think. Should be able to use the resulting Indigo device status as a quasi monitor for the container being "up" as well!
/Marty
Sat Sep 24, 2022 7:19 am
Stoutjesdijk offline
I run a UDM, latest update. I get the following error message. Have tried all kinds of login settings, but I cannot figure out how to get rid of this problem. What am I doing wrong here?
  Starting plugin "uniFiAP 2022.40.382" (pid 22963)
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         detailed logging        /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.uniFiAP/plugin.log
   uniFiAP                         testing logging levels, for info only:
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
   Started plugin "uniFiAP 2022.40.382"
   uniFiAP                         debug settings :['Logic', 'Log', 'LogDetails']
   uniFiAP Error                   Expecting value: line 1 column 1 (char 0); line#,Module,Statement:(355, 'raw_decode', 'raise JSONDecodeError("Expecting value", s, err.value) from None')
   uniFiAP Error                   UNIFI executeCMDOnController error no json object: (wrong UID/passwd, ip number?192.168.1.1) ...>><<
   uniFiAP                         initialized ... looping
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Sat Sep 24, 2022 7:23 am
Do you have 2 factor auth. enabled?
Sat Sep 24, 2022 7:48 am
Nope, I have no 2FA anywhere yet in my unifi setup...
Best regards,
Mark
Sat Sep 24, 2022 8:46 am
UDM or UDM pro?
And that is new?
Sat Sep 24, 2022 9:37 am
** UPDATE **
Seems it was a port problem; I manually set the port to 443 and I have no errors anymore. :D
Ah, sorry. It is indeed a UDM pro. It is located at 192.168.1.1. This is a first install, so indeed.a new problem.
I double checked the following:
I can log in to the web interface at 192.168.1.1 using the user/pw combination #1.
I can ssh in to an AP using the user/pw combination #2.
I can ssh into the UDM pro using the user/pwd combination #3.
There must be some other problem :(
Thanks for your help!
Best regards,
Mark
