Devices not added, password wrong, but it is correct!
Sun Mar 18, 2018 6:30 am
patrikhson offline
I am using version 1.7.12.101 of the plugin, 7.1.1 of the Indigo software.
When I log into an access point myself manually, it works:
$ ssh paf@192.165.72.91
paf@192.165.72.91's password:
BusyBox v1.11.2 (2016-04-01 14:55:04 PDT) built-in shell (ash)
Enter 'help' for a list of built-in commands.
BZ.v3.3.20#
It seems to also work when I look in the logs, but as you see it still believe IP/password or something is broken. To me that implies a bug in the expect script.
===========192.165.72.94  ==> spawn ssh paf@192.165.72.94
paf@192.165.72.94's password:
exit
BZ.v3.3.20# exit
Connection to 192.165.72.94 closed.
   getMessages
 FATAL error connecting to ip#: 192.165.72.94 wrong ip/ password ...?
================================================n
No devices are added, so something is clearly broken. Maybe it is me? :-)
Patrik
Sun Mar 18, 2018 6:38 am
Re: Devices not added, password wrong, but it is correct!
Can you do the following on the indigo server box :
open terminal
ssh userid@ipnumber
Enter password
A) does it work
B) how long does it take>15 secs? ==> timeout??
C) what is the prompt
Sat Mar 31, 2018 4:11 pm
Hi Karl.
I'm getting similar to the above.
I've only just got my head around your Unify plugin and the fact I need the Controller software running all the time - I normally only fire it up when I need to change something on my single AP.
23:02:53 START                    -AP Thread # 0  192.168.3.45
23:02:53 START                    -launching 192.168.3.45
23:02:53 KILL                     -killing request: ps -ef | grep uniFiAP | grep '192.168.3.45 ' | grep /usr/bin/expect | grep execLog.exp | grep -v grep
23:02:53 EXPECT                   -/usr/bin/expect  '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' Administrator PASSWORD 192.168.3.45
23:02:53 KILL                     -killing request: ps -ef | grep uniFiAP | grep '192.168.3.45 ' | grep /usr/bin/expect | grep dictLoop.exp | grep -v grep
23:03:00 testConnection           -
===========192.168.3.45  ==> spawn ssh Administrator@192.168.3.45
Administrator@192.168.3.45's password:
BusyBox v1.11.2 (2017-05-08 09:43:54 PDT) built-in shell (ash)
BZ.v3.7.58#
23:03:00 getMessages              -
 FATAL error connecting to ip#: 192.168.3.45 wrong ip/ password ...?
BZ.v3.7.58#
A) Yes, it works.
B) Instant
C) BZ.v3.7.58#
BZ.v3.7.58# info
Model:       UAP
Version:     3.7.58.6385
MAC Address: 44:d9:e7:d6:b4:21
IP Address:  192.168.3.45
Hostname:    HallAP
Uptime:      960 seconds
Status:      Connected (http://192.168.3.6:8080/inform)
BZ.v3.7.58#
Peter
Sat Mar 31, 2018 4:15 pm
ps, I can run mca-dump using the startDictToken from your plugin and that works.
It just doesn't seem to be seeing the prompt in expect and thus not continuing.
Peter
Sat Mar 31, 2018 4:32 pm
Ah....
In testServerIfOK, you are looking for "Welcome" in the banner prompt after logging in, which doesn't exist.
I just changed it to "BusyBox" temporarily and it immediately found and created my devices.
Peter
Sat Mar 31, 2018 11:52 pm
Thanks for testing. Will check when I am home.
Mon Apr 02, 2018 4:00 am
this is what I see for switches, AP, cloudkey, gateway.. mine all have "Welcome"
BusyBox v1.23.2 (2018-01-19 23:57:52 MST) built-in shell (ash)
  ___ ___      .__________.__
 |   |   |____ |__\_  ____/__|
 |   |   /    \|  ||  __) |  |   (c) 2010-2018
 |   |  |   |  \  ||  \   |  |   Ubiquiti Networks, Inc.
 |______|___|  /__||__/   |__|
            |_/                  http://www.ubnt.com
      Welcome to UniFi USW-24P-250!
US.v3.9.21#
BusyBox v1.19.4 (2018-02-13 10:32:51 MST) built-in shell (ash)
      Welcome to UniFi UAP-AC-Pro-Gen2!
AP-1-Server-BZ.v3.9.24#
 |   |   /    \|  ||  __) |  |   (c) 2013-2017
      Welcome to UniFi CloudKey!
Last login: Sun Mar 18 12:17:42 2018 from 192.168.1.53
root@UniFi-CloudKey:~#
Linux ubnt 3.10.20-UBNT #1 SMP Fri Nov 3 15:45:37 MDT 2017 mips64
 |   |   /    \|  ||  __) |  |   (c) 2010-2017
      Welcome to EdgeOS on UniFi Security Gateway!
*NOTE*: Configuration changes made here are not persistent.
They will be overwritten by the controller on next provision.
Last login: Sun Apr  1 22:20:04 2018 from 192.168.1.50
karlwachs@GW:~$
what are your prompts.. and what are your versions ?
Mon Apr 02, 2018 8:31 am
I will add:
If xx.find(“Welcome”)>-1: return True
If xx.find(“UniFi”) > -1: return True
If xx.find(“Edge”)>-1: return True
If xx.find(“busy”)> -1: return True
That should cover all variations
Any other?
The purpose of this check is to see if the box answers.
Mon Apr 02, 2018 9:40 am
— moved to plugin store —-
if someone could test this version.
have added several options for checking the login prompt:
Welcome, UniFi, Edge, BusyBox,...
I am still not at home and can not test
Mon Apr 02, 2018 1:03 pm
I'll test shortly.
Mon Apr 02, 2018 2:37 pm
Download Moved to plugin store. ——
had the filename wrong
please use this one.
doing things remotely is not that easy
Mon Apr 02, 2018 3:00 pm
Thanks, that's working.
My welcome message is:
BZ.v3.7.58#
As you can see, I don't get the funny ASCII art or the "Welcome..." message.
Peter
Mon Apr 02, 2018 3:36 pm
Looks like an older version.
