- Code: Select all
uniFiAP in Line '1746' has error=''NoneType' object is not iterable'
Just upgraded. Not sure if this is new since then, or a one off, or something that happens occasionally.
uniFiAP Error --------------------------------------------------------------------------------------------------------------
uniFiAP Error The pluginName is not correct, please reinstall or rename
uniFiAP Error It should be /Libray/....../Plugins/uniFiAP.indigoPlugin
uniFiAP Error It is: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP-2.indigoPlugin
uniFiAP Error please check your download folder, delete old *.indigoPlugin files or this will happen again during next update
uniFiAP Error ---------------------------------------------------------------------------------------------------------------
Error plugin "uniFiAP-2.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP-2.indigoPlugin/Contents/Info.plist
uniFiAP in Line '1775' has error=''NoneType' object is not iterable'
