in Line '1746' has error=''NoneType' object is not iterable'
Fri Feb 09, 2018 7:24 pm
   uniFiAP                         in Line '1746' has error=''NoneType' object is not iterable'
Just upgraded. Not sure if this is new since then, or a one off, or something that happens occasionally.
Fri Feb 09, 2018 11:07 pm
Re: in Line '1746' has error=''NoneType' object is not itera
which version? could you re-download the latest.
line 1746 in the last 2 version is in the menu section.. never executed if you don't explicitly do a menu command..
7.10.88 is the latest
here the link to my dropbox, https://www.dropbox.com/s/vv4wbwuhs1vpq6q/uniFiAP-v-7.10.88.zip?dl=1
same in the indigo store https://www.indigodomo.com/pluginstore/73/
Sat Feb 10, 2018 7:06 am
I had just dl'ed .85. I’ll try the latest this morning.
Sat Feb 10, 2018 9:26 am
Guess the caffeine hasn't kicked in yet.
I got into an upgrade mess because the download was auto-renamed to unifiap-2 since there was already a unifiap in my dl folder.
I foolishly double clicked it and it installed but then I got
uniFiAP Error                   --------------------------------------------------------------------------------------------------------------
   uniFiAP Error                   The pluginName is not correct, please reinstall or rename
   uniFiAP Error                   It should be   /Libray/....../Plugins/uniFiAP.indigoPlugin
   uniFiAP Error                   It is: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP-2.indigoPlugin
   uniFiAP Error                   please check your download folder, delete old *.indigoPlugin files or this will happen again during next update
   uniFiAP Error                   ---------------------------------------------------------------------------------------------------------------
Tried various things like renaming the plugin, and now I get
 Error                           plugin "uniFiAP-2.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP-2.indigoPlugin/Contents/Info.plist
Things I've tried:
renaming the plugin in the plugin folder.
Renaming the plugin and reinstalling. This gets an "already installed" message.
Disabling and reloading.
Disabling, removing from the plugin folder, reinstalling.
All still generate an error.
OK wait--I just reloaded the misbehaving plugin to see whether or not it was functioning despite these errors, and now it doesn't throw any errors of complaining about the plugin name. Odd.
But, like a bad penny:
 uniFiAP                         in Line '1775' has error=''NoneType' object is not iterable'
Sat Feb 10, 2018 4:17 pm
Ok
disable the plugin if not server stop done
Then rename anything like -2 to regular Name or delete.
You might need to stop the server first as the old one is still running
You might have 2 running in parallel
One regular and one with -2
Sat Feb 10, 2018 5:52 pm
I've done all that delete stuff. I'm 99% certain there's only 1 plugin running. Also, I notice the line number has changed from the original error to the current one.
Sat Feb 10, 2018 6:12 pm
What’s your version#?
And what error messages are there?
ps if you like we can do an online session with teamviewer .. send me your login info .. we should be able to fix this quickly
Sat Feb 10, 2018 6:35 pm
ok found it ..
with
xxx = abc()
in abc
return {}
and one just
return
then doing
for a in xxx:
that does not work when xxx is None
This only happens when auto discovery is turn off. That is why I don't see it
will post a fix soon.
Sat Feb 10, 2018 6:51 pm
posted fixed version . .89 @ https://www.indigodomo.com/pluginstore/73/
