how would i...
Mon Dec 04, 2017 6:32 pm
Seeker offline
how would i...
i just got this installed and am playing around with it.
if i want to trigger based on my iPhone being up/home or down/away, how would i go about that? I see in config i can set a group, but it appears be all 'regular devices through wifi' added to a group. how do i pick individual items for monitoring or triggers?
Mon Dec 04, 2017 6:45 pm
Re: how would i...
In device edit for the UniFi devices add to the groups.
You can set a trigger on device/status == up / not up
BUT you need to tune the expiration settings. There are many options depending what you want to do.
There is
fast down will only check the ap messages
WiFi several options
Switch if you have a switch but not good for WiFi devices
DHCP uses dhcp table info from the gateway.
Etc.
