OK to change auto-created group variable names?
Sun Nov 05, 2017 2:28 pm
Different Computers offline
Will the plugin freak if I change an automatically created variable (like "Unifi-Count-Group2-Home") to something else? Will the plugin still update that variable if I change its name?
Mon Nov 06, 2017 5:48 am
Re: OK to change auto-created group variable names?
it will re-create the old one and will update the old one.
If it should do what you want it would need to have a config section to set a name for each of the "types".
Mon Nov 06, 2017 9:02 am
Thanks. When you say "update" do you mean it keeps good data in the variable whose name has been changed?
Mon Nov 06, 2017 9:18 am
It will ignore anything that does not have the predefined names
So it will only update the variables it knows. The names are hardwired.
The plugin “recycles” (= deletes and recreates )some of the variables at midnight
This is done to make sqllogger delete the tables for these variables. The contents of these variables do not need to be time tracked. ( name of changed device etc). This helps the sql dB - at least for Postgres- to keep the sqldatabase smaller. If a table is deleted that space ( a file in the case of Postgres ) gets completely deleted.
Mon Nov 06, 2017 10:21 am
Thanks for the explanation.
Guess I'll have to rely on my brain to remember which group number is for which thing. Dangerous! :D
Mon Nov 06, 2017 10:59 am
Or you could just maintain a variable ID map so that if the user changes the name it doesn't effect operation because you're using the ID.
Mon Nov 06, 2017 11:42 am
Yes, I thought about that, but if the variable is deleted it will not work. In my environment some of these get updates veryyyyy frequently. Hence I like to recycle the variable
And indigo only offers to purge/prune all variables to the same date.
Mon Nov 06, 2017 8:07 pm
Which is the case either way, so it's not really relevant to the discussion.
I don't understand...
Mon Nov 06, 2017 9:39 pm
here we go:
1. with 10 variables being updated 1/sec with ~ 20 bytes per update , 80k secs in day creates ~ 16Mbyte / day = 5+ GB in a year, just for these variables.
2. as indigo does not allow individual pruning of variables ( could be done outside indigo) it is either keep all variables or none beyond pruning date.
3. when deleting and recreating the variables the database - postgres- deletes all the old data files related to the variables - and sets up new ones so no increase in DB size (not true for SQLite)
4. names vs id: when a user is allowed to rename the variable and the variable gets deleted the link between id and name is gone. One could store the new name and recreate the new set of variables using the new name, but that makes the management somewhat complex (if e.g. user does not rename but copy or delete... )
So in order to keep things a little bit simpler, I decided to fix the names and delete and recreate them after midnight and the user can simply use the name for triggers etc.
