uniFi AP username / password
Tue Aug 22, 2017 9:37 am
siclark offline
It might be obvious for those that have setup their own site controller, but I bought my APs through broadbandbuyer.com in the UK and they host the cloud controller themselves and supply pre provisioned, with themselves as super admin, and myself as admin.
It took me a lot of searching, and frustrated attempts to log on before I found that the relevant password for the plugin is for the Site, as seen in the Settings > Site > Device Authentication at the bottom. Clicking on the dots shows the password.
Hopefully this helps save others some headaches...
On a related setup issue as a new user. I had errors starting straight onto the latest version. Eventually I got a version 1.xx plugin working and then upgraded through a series of them all without issue until I got to the latest. Not sure what was the problem, but all working now.
Tue Aug 22, 2017 10:59 am
Re: uniFi AP username / password
Could you share which error occurred when you used the latest version. That is difficult to test for me I hate to delete everything and start from scratch.
E.g. Send me the logfile with error messages.
Wed Aug 23, 2017 5:05 am
siclark offline
Actually, looking back through the logs, I think it was a problem that I downloaded it twice and tried to install the one with the 2 in the name. I then deleted everything and when I started again it installed correctly.
Wed Aug 23, 2017 5:20 am
Yes that would do it. But it should complain about it if the name contains a -.2
Thu Nov 30, 2017 8:31 am
evansgo offline
Awesome, this one caught me out too thanks very much :)
Sun Dec 03, 2017 6:13 am
Seeker offline
I am still stumped on getting this plugin to work. i tried a couple of weeks ago and gave up.
Starting plugin "uniFiAP 7.9.76" (pid 38513)
   uniFiAP                         setting parameters for indigo version: >>7<<
   Started plugin "uniFiAP 7.9.76"
   uniFiAP                         initializing  ... variables
   uniFiAP                          start  runConcurrentThread, initializing variables ..
   uniFiAP                         ..getting missing vendor names for MAC #
   uniFiAP                         ..starting threads for 1 APs 4 sec apart (MSG-log and db-DICT)
   MS-----                         192.168.1.123  0  APtail  AP
['spawn ssh admin@192.168.1.123', "admin@192.168.1.123's password: ", 'Permission denied, please try again.\r', "admin@192.168.1.123's password: "]
   MS-AP----                       192.168.1.123-0  spawn ssh admin@192.168.1.123
   MS-AP----                       192.168.1.123-0  admin@192.168.1.123's password:
   MS-AP----                       192.168.1.123-0  Permission denied, please try again.
   uniFiAP                         ..starting threads for 1 SWs 14 sec apart (db-DICT only)
   uniFiAP                         initialized
Dec 3, 2017 at 6:06:43 AM
['end', '', '']
   MS-AP----                       192.168.1.123-0  end
['Permission denied, please try again.\r', "admin@192.168.1.123's password: "]
unifi plugin.png (288.29 KiB) Viewed 4214 times
unifi indigo.png (50.26 KiB) Viewed 4214 times
Sun Dec 03, 2017 8:57 am
Please do:
Open terminal on the indigo mac
ssh id@192.168.1.123
Enter passwd
If that gives an error you have the wrong uid paaswd
If that works: what is the prompt ?
Sun Dec 03, 2017 2:50 pm
Seeker offline
i get permission denied, please try again.
I'm stuck because i don't remember setting up a PW for the AP. I just adopted it via the controller. is there a place or way to see what the AP login is?
Thank you.
Mon Dec 04, 2017 12:51 am
Same uid and passwd as the UniFi controller.
Mon Dec 04, 2017 4:39 am
Seeker offline
thanks. that's what i'm using and it does not work. i still get the pw error in the log.
Mon Dec 04, 2017 8:28 am
when you do it manually in a terminal, does it work there?
Mon Dec 04, 2017 8:47 am
Seeker offline
No, it gives the password invalid error.
UniFi system is working fine.
Mon Dec 04, 2017 8:57 am
if THAT does not work the plugin CAN NOT work. It does the same.
are you sure about the UID/PASSwd ?
if you like we can do a teamviewer session.
Mon Dec 04, 2017 3:38 pm
Seeker offline
SUCCESS! at least it loads and populates the devices.
The only thing i changed was changing the username and password in the config/setting/site/device authentication section. my previous password was 28 characters long. I changed it to 8 and it worked, then 18 chars and it works. not sure if this had anything to do with it (pw too long at 28?) or if it was something else to do with the changing of the u/pw.
edit: just changed it back to a 28 char pw and it still works.
anyway, it seems to be loading now. thank you!
Mon Dec 04, 2017 5:22 pm
Might not work If you have a space in there. Other characters should be fine.
