uniFi-WiFI-AP: discussions
Thu Jul 27, 2017 8:26 pm
Re: uniFi-WiFI-AP: discussions
A few seconds later, it goes back to the original.
thats correct behavior.. the plugin is programmed to do that. if you like to switch that off. I can add an option..
the second case is a bit more complicated..
The plugin gets some "names" from different devices (gateway, AP, switch if you have) they all can be different ..
Then on the IP some devices can change their IP number ..
the plugin is uses ONLY the mac number as key. everything else is linked to it. If it gets anything with a mac number it will update all props of that MAC number accordingly
so, could you observe it a bit more and get me some more stats..
thanks for your help
Sat Jul 29, 2017 7:23 am
jrcitizen offline
It would be nice to have an option allowing us to both rename the Device name as well as the Device Description. Hope it is not too much trouble to add :D
Sat Jul 29, 2017 8:28 pm
see version 7-5-43 ..
hope that does it for you.
Sat Jul 29, 2017 8:37 pm
roquej offline
Thank you!
Sat Jul 29, 2017 9:07 pm
please reload.. v 44.. the off worked the on did not
Sat Aug 05, 2017 12:53 pm
Different Computers online
Hey, with some update a while ago I suddenly got a whole bunch of new automatically created variables with names like "Unifi-Count-Group0-Away".
Did I miss the explanation of what these are designed to be used for?
Sun Aug 06, 2017 4:35 pm
you can put unify devices into a group (one of 10) in device edit
then you will get # of devices in this group at home / away
you can set triggers e.g.
if variable Unifi-Count-Group6-Home value ==1 ==> at least on member home
if variable Unifi-Count-Group6-Home value ==4 ; (with 4= all members in this group): all home
if variable Unifi-Count-Group6-Away value ==1 ==> at least on member away
etc.
Screen Shot 2017-08-06 at 17.33.54.png (41.69 KiB) Viewed 3504 times
Mon Aug 07, 2017 7:10 am
Gotcha! Thanks.
I had to move my Indigo install to another computer yesterday. Perhaps unrelated, but today I'm seeing
   uniFiAP                         in Line '2781' has error='NameNotUniqueError'
Mon Aug 07, 2017 9:05 am
that could happen if you have renamed, removed etc a device.
please set debug on and check which device it is complaining about.
then delete that device. it should be recreated.
I am leaving in an hour. can not fix anything in the next 3 weeks
Tue Oct 31, 2017 5:30 pm
Deleted(*) a reply to the announcement thread (fixed the error) as I would like to keep it short. ..
discussions etc should go here or in a topic you start... ..
forgot to set lock option in the announcement post
(*) don't know how to move a post to another thread.
Wed Nov 01, 2017 3:54 pm
petematheson offline
Hi Karl,
First time installing and setting this plugin up.
1. The instructions you have don't seem to match the latest version I've downloaded? (yours shows a username/password field. I don't see that option anywhere)
2. When starting the plugin I'm getting the errors below. Possibly because they're not authenticated?
Started plugin "uniFiAP 7.9.63"
uniFiAP initializing ... variables
uniFiAP in Line '97' has error=''list' object has no attribute 'find''
uniFiAP killing request: ps -ef | grep 192.168.0.170 | grep /usr/bin/expect | grep -v grep
uniFiAP killing request: ps -ef | grep 192.168.0.168 | grep /usr/bin/expect | grep -v grep
uniFiAP killing request: ps -ef | grep 192.168.0.133 | grep /usr/bin/expect | grep -v grep
uniFiAP killing request: ps -ef | grep 192.168.0.169 | grep /usr/bin/expect | grep -v grep
Wed Nov 01, 2017 4:02 pm
Karl - the latest release(s) have hidden the authentication fields behind the enabling of the UGA (you mean USG?). Also the fields for naming the variable folders also require enabling the USG. Was this a deliberate change? The plugin was working fine for me with just three WAPs.
Wed Nov 01, 2017 4:36 pm
So i downloaded the previous version, entered the username / password, then upgraded to the newer version and it's now bringing the devices in.
However I still have tonnes of errors?
uniFiAP in Line '1767' has error='u'1406103281''
uniFiAP looking at device: UniFi_992588996887_ac:63:be:64:2e:fd
uniFiAP in Line '1767' has error='u'667656477''
uniFiAP looking at device: UniFi_ac:63:be:37:ec:a3
uniFiAP in Line '1767' has error='u'1686121441''
uniFiAP looking at device: UniFi_ac:63:be:64:2e:fd
uniFiAP in Line '1767' has error='u'1157854535''
uniFiAP looking at device: UniFi_00:04:20:f4:d8:56
uniFiAP in Line '1767' has error='u'98783327''
uniFiAP looking at device: UniFi_50:f5:da:0f:48:0c
uniFiAP in Line '1767' has error='u'182659678''
uniFiAP looking at device: UniFi_720346927643_50:f5:da:0f:48:0c
Thu Nov 02, 2017 2:45 pm
I'm not getting the errors that Pete is getting. But there's still some issues with the config panel.
Typo on top: UniFi, not UNIFY. Switch not Swithc.
The username/password fields are hidden. The section after "changes in the following parameters..." should be showing, I think. Also "changes" should be capitalized.
Those triple lines after the switch list make me think there's supposed to be something showing there as well, but enabling a switch did not show them.
Screen Shot 2017-11-02 at 4.38.03 PM 11-2.png (424.67 KiB) Viewed 3178 times
Thu Nov 02, 2017 3:48 pm
My errors have gone with the latest version, but still no username and password fields as above
