uniFi-WiFI-AP: discussions
Fri May 18, 2018 4:12 pm
Re: uniFi-WiFI-AP: discussions
Ok that helps. It is restarting itself as it thinks “there are new devices ....”
Will check
And the version error is from indigoutilities that happens to check ITS version at that same period of time. And it finds the wrong version#
Fri May 18, 2018 4:46 pm
https://www.indigodomo.com/pluginstore/73/ v ...111 should fix that
                for dev in indigo.devices.iter(self.pluginId+"props.isAP,props.isSwitch,props.isGateway"):  ### wrong
                for dev in indigo.devices.iter(self.pluginId+",props.isAP,props.isSwitch,props.isGateway"):  ### fixed
Sun May 20, 2018 6:24 pm
roquej offline
Karl,
V111 took care of the last issue. However, now we have:
"uniFiAP in Line '4304' has error='No JSON object could be decoded',receiving DICTs for 192.168.X.148; check unifi logfile; if this happens to often increase DICT timeout "
X.148 is an UniFi AP-AC-Pro
Thoughts?
JP
Sun May 20, 2018 7:25 pm
How often?
Sun May 20, 2018 7:30 pm
roquej offline
Only once so far. If it comes up again, will let you know.
JP
Sun May 20, 2018 8:12 pm
once can happen , just some time out .. if it occurs again
check dict-AP#1-Seq-0.txt if that looks like a json dumps of a dict. some thing like this:
  "antenna_table": [
      "id": 4,
      "name": "Combined",
      "wifi0_gain": 3,
      "wifi1_gain": 3
  "board_rev": 26,
  "bootid": 1,
  "bootrom_version": "unifi-v1.6.13.275-g65f82952",
  "cfgversion": "2f6904683eb85af6",
  "connect_request_ip": "192.168.1.4",
  "connect_request_port": "46559",
  "country_code": 840,
  "countrycode_table": [
    840,
    124,
    630
  "default": false,
And or set debug ssh on looks or
/usr/bin/expect  "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/dictLoop.exp" usid pwd192.168.1.3 BZ.v xxxThisIsTheEndTokenxxx 60 40 "mca-dump | sed -e 's/^ *//'"   /var/log/messages
open terminal and copy and paste, use you userid and password and ip number
check out the response if it looks like a dict dump its ok :
AP-0-study-BZ.v3.9.27# startxxxx
AP-0-study-BZ.v3.9.27# mca-dump | sed -e 's/^ *//'
"antenna_table": [
"id": 4,
"name": "Combined",
"wifi0_gain": 3,
"wifi1_gain": 3
"board_rev": 26,
"bootid": 1,
"cfgversion": "b9f5a009cd1f2998",
"connect_request_ip": "192.168.1.3",
"connect_request_port": "44523",
840,
124,
630
"default": false,
"discovery_response": false,
