Bridge connects but no devices are shown
Thu Sep 28, 2017 5:35 am
Dewster35 offline
I have the homebridge as an accessory but no indigo devices are showing as available in either the stock Home App or in the MyTouchHome app on my iphone. I'm running iOS 11 on the iphone and sierra on the server.
File Sep 28, 7 25 25 AM.png (247 KiB) Viewed 3473 times
Thu Sep 28, 2017 7:53 am
webdeck offline
Re: Bridge connects but no devices are shown
Did you upgrade as described in this post? viewtopic.php?f=191&t=18888
Thu Sep 28, 2017 9:32 am
Colorado4Wheeler offline
I've had this happen to me before, and it was the result of adding the same accessory too many times and the database gets wonky. Try changing the port on the configuration up or down a number, this will force Home to refresh itself and may fix your problem.
Thu Sep 28, 2017 7:06 pm
Dewster35 offline
wow... sorry for the mega sized images!
I did update according to those instructions.
I also just tried to do the port change thing. Changed it, ran home bridge and then changed it back. Still nothing.
I tried deleting the bridge in the thoughts that I could try to add it back but now that isn't even showing up as a available anymore.
Any other thoughts or troubleshooting?
Thu Sep 28, 2017 10:14 pm
webdeck offline
It sounds like something on the iOS side is corrupted. Try the three resetting suggestions in this post: viewtopic.php?f=191&t=19084#p145553
Fri Sep 29, 2017 4:32 pm
Dewster35 offline
That did it! Oddly enough, there was an Homebridge for Indigo and Homebridge. Two separate devices. I chose home bridge only. Homebridge for Indigo was what I chose before.
Fri Sep 29, 2017 4:55 pm
webdeck offline
Did you install the Homebridge Buddy plugin in Indigo by any chance? That has its own separate homebridge server.
Fri Sep 29, 2017 4:58 pm
Dewster35 offline
Yes I did. Which one is the other plugin's?
Also... I did search, but couldn't find how to add thermostats? The treat as type didn't include thermostats...
Fri Sep 29, 2017 9:56 pm
webdeck offline
The only thermostats supported currently are the ones that Indigo natively supports (i.e. not via a plugin.)
