No response from devices
Sat Sep 23, 2017 2:00 pm
Jim offline
Things have been working fine for months. All of a sudden all devices in all rooms show "No Response" (see attached). Not sure if this was caused by iOS 11 but I went through and upgraded npm, nodejs, homebridge and home bridge-indigo per post. When I start homebridge (with the -D) it detects all the devices and creates 45 accessories.
Any hints?
Also where are the homebridge logs? I can not find them in ~/Library/Logs/homebridge.log or /Library/Logs/homebridge.log
Jim
Screen Shot 2017-09-23 at 12.59.22 PM.jpeg (370.2 KiB) Viewed 8888 times
Sat Sep 23, 2017 2:14 pm
webdeck offline
Re: No response from devices
Sat Sep 23, 2017 2:21 pm
Jim offline
Thanks for the quick reply. In the post are you referring to the upgrade or the last post about lower network info? I did do the upgrade.
Jim
Sat Sep 23, 2017 2:42 pm
webdeck offline
Sorry.- I was on my phone and saw ios11 but missed that you updated.
Make sure you restart homebridge after upgrading to make sure the new version is running. Not sure why you don’t have the log file - that makes it hard to troubleshoot.
Sat Sep 23, 2017 3:06 pm
Jim offline
jim$ homebridge --version
0.4.28
Let me see if maybe there is a permissions issue with writing the logs.
Sat Sep 23, 2017 3:09 pm
webdeck offline
Look at the process list to see how long homebridge has been running. If it was started before your upgrade then you still have the old version running and need to stop and restart it.
Sat Sep 23, 2017 3:33 pm
webdeck offline
One other thing - are you running it via the command line or via launchctl? The log files get created if you use launchctl according to the instructions I provided. If you're just running it on the command line, then the output goes to the terminal directly.
Does it work when you run it from the command line? If so, then you don't have a launchctl version running properly.
If you run from the command line and get EADDRINUSE, that means it is already running in another process (probably via launchctl.)
-Mike
Sat Sep 23, 2017 3:45 pm
Jim offline
Hey Mike.
1) I quit home bridge and did ps -eaf | grep home and there were no old home bridge processes running.
2) I have always started it from the command line and never launchctl so that explains why no logs.
3) Not getting EADDRINUSE
4) Does all debug (-D) go to the terminal or would extra debug info go to the log?
Jim
Sat Sep 23, 2017 4:19 pm
webdeck offline
When running via launchctl, there is no terminal window, so the terminal output is sent to the log file instead. They have the same content.
Please post the full output so I can try to see what's wrong.
Sat Sep 23, 2017 4:41 pm
Jim offline
- I have HomeKit device (August Lock) and it is reporting fine.
- I also tried using one of the URLs and after logging in it returned the device data.
- I did a few things web research said like rebooting the router.
Still no go.
If this doesn't have a tell in it I will try dropping the home and rebuilding it.
Jim
jim$ homebridge -D
[9/23/2017, 3:34:19 PM] Loaded plugin: homebridge-indigo
[9/23/2017, 3:34:19 PM] Registering platform 'homebridge-indigo.Indigo'
[9/23/2017, 3:34:19 PM] ---
[9/23/2017, 3:34:19 PM] Loaded config.json with 0 accessories and 1 platforms.
[9/23/2017, 3:34:19 PM] Loading 1 platforms...
[9/23/2017, 3:34:19 PM] [My Indigo Server] Initializing Indigo platform...
[9/23/2017, 3:34:19 PM] [My Indigo Server] Indigo base URL is http://127.0.0.1:8176
[9/23/2017, 3:34:19 PM] Loading 0 accessories...
[9/23/2017, 3:34:19 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices.json/
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Atrium%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (ID 1970232672): Atrium Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Atrium%20Outlet.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc Dimmer (dual-band) (ID 1728490326): Atrium Outlet
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Back%20Ha ... Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1734529108): Back Hallway Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bar%20Amp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Virtual On/Off Device (ID 1492622622): Bar Amp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1492622622
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bar%20Garland.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 677472651): Bar Garland
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bar%20Lamp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 429292516): Bar Lamp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bar%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc V2 Dimmer (ID 109813312): Bar Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Basement%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered 8 Watt LED Bulb (2672) (ID 1648250242): Basement Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bedroom%20Lamp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 107134042): Bedroom Lamp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Bedroom%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Virtual On/Off Device (ID 137040859): Bedroom Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 137040859
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Christmas%20Tree.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered ApplianceLinc V2 (ID 1108769857): Christmas Tree
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Deck%20Sconces.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (dual-band) (ID 44280174): Deck Sconces
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Deck%20Step%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered ApplianceLinc V2 (ID 347331320): Deck Step Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Den%20Sconces.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (ID 922971527): Den Sconces
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/DR%20Ambient%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (ID 1383789117): DR Ambient Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/DR%20Table%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (ID 1534079616): DR Table Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Entertaining.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Virtual On/Off Device (ID 157558781): Entertaining
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 157558781
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/EZRain.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered EZFlora Irrigation Controller (ID 1926738384): EZRain
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring unknown accessory type EZFlora Irrigation Controller
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Fenway%20Park.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 967532562): Fenway Park
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Fountain.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered In-LineLinc Relay (ID 465476577): Fountain
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Front%20H ... Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc V2 Dimmer (ID 99118491): Front Hallway Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Front%20P ... conce.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc V2 Dimmer (ID 1285490448): Front Porch Sconce
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20Door.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered I/O-Linc Controller (ID 365469773): Garage Door
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring unknown accessory type I/O-Linc Controller
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered 8 Watt LED Bulb (2672-222) (ID 55926818): Garage Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Jalapena%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc (ID 786205601): Jalapena Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%2 ... ights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc Dimmer (dual-band) (ID 61737433): Kitchen Cabinet Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Virtual On/Off Device (ID 1145558344): Kitchen Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%2 ... Light.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc V2 Dimmer (ID 1750963960): Kitchen Table Light
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (dual-band) (ID 547730618): Kitchen Track Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Low%20Vol ... ft%29.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered ApplianceLinc V2 (ID 1460297483): Low Voltage (Back Left)
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Low%20Vol ... ht%29.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered ApplianceLinc V2 (ID 863157765): Low Voltage (Back Right)
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Low%20Vol ... nt%29.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered ApplianceLinc V2 (ID 816440233): Low Voltage (Front)
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Floor%20Lamp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 1309882618): LR Floor Lamp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Hutch.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc Dimmer (dual-band) (ID 1594303164): LR Hutch
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Palm%20Left.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 1749786141): LR Palm Left
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Palm%20Right.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc Dimmer (dual-band) (ID 440855159): LR Palm Right
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Track%20Left.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (dual-band) (ID 680202713): LR Track Left
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Track%20Right.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered SwitchLinc Dimmer (dual-band) (ID 526216237): LR Track Right
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/LR%20Victrola%20Lamp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc Dimmer (dual-band) (ID 874795252): LR Victrola Lamp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Office%20Lamp.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered 8 Watt LED Bulb (2672-222) (ID 1663374188): Office Lamp
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Power%20O ... 0Left.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc (ID 400863933): Power Outlet Left
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Power%20O ... iddle.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc (ID 1285095099): Power Outlet Middle
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Power%20O ... Right.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc (ID 1779228534): Power Outlet Right
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Rain%20Amount.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered WeatherSnoop 3 Agent (ID 1742869399): Rain Amount
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring unknown accessory type WeatherSnoop 3 Agent
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Trellis%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered OutletLinc (ID 1760573556): Trellis Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Umbrella%20Lights.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc V2 (ID 1863079115): Umbrella Lights
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Wreath%20-%20Gate.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered LampLinc (dual-band) (ID 1445515759): Wreath - Gate
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions.json/
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Bar%20Amp%20Off.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1921284617): Bar Amp Off
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Bar%20Amp%20On.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1130900897): Bar Amp On
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Entertaining%20Off.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 803999648): Entertaining Off
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 803999648
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Entertaining%20On.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 713698049): Entertaining On
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 713698049
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Flag%20%40%20Sunrise.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 74149769): Flag @ Sunrise
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Flag%20%40%20Sunset.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1756306643): Flag @ Sunset
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Good%20Morning.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1603962045): Good Morning
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1603962045
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Good%20night.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1544913063): Good night
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1544913063
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Hot%20summer%20night.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1183959925): Hot summer night
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1183959925
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Kitchen%2 ... 20Off.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1500459161): Kitchen Lights Off
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1500459161
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Kitchen%2 ... %20On.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1190242359): Kitchen Lights On
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1190242359
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Start%20Watering.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 91275662): Start Watering
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 91275662
[9/23/2017, 3:34:20 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions/Wake-up.json
[9/23/2017, 3:34:20 PM] [My Indigo Server] Discovered Action (ID 1079796165): Wake-up
[9/23/2017, 3:34:20 PM] [My Indigo Server] Ignoring excluded ID 1079796165
[9/23/2017, 3:34:20 PM] [My Indigo Server] Created 45 accessories
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Atrium Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Atrium Outlet'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Back Hallway Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bar Amp Off'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bar Amp On'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bar Garland'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bar Lamp'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bar Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Basement Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Bedroom Lamp'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Christmas Tree'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'DR Ambient Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'DR Table Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Deck Sconces'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Deck Step Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Den Sconces'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Fenway Park'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Flag @ Sunrise'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Flag @ Sunset'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Fountain'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Front Hallway Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Front Porch Sconce'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Garage Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Jalapena Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Kitchen Cabinet Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Kitchen Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Kitchen Table Light'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Kitchen Track Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Floor Lamp'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Hutch'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Palm Left'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Palm Right'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Track Left'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Track Right'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'LR Victrola Lamp'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Low Voltage (Back Left)'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Low Voltage (Back Right)'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Low Voltage (Front)'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Office Lamp'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Power Outlet Left'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Power Outlet Middle'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Power Outlet Right'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Trellis Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Umbrella Lights'...
[9/23/2017, 3:34:20 PM] [My Indigo Server] Initializing platform accessory 'Wreath - Gate'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[9/23/2017, 3:34:20 PM] Homebridge is running on port 51826.
Sat Sep 23, 2017 9:50 pm
webdeck offline
Okay, so no errors there. Does it output anything else when you're trying to access your devices via Homekit?
If that isn't logging anything, then something is messed up on the iOS side and you would need to nuke everything and start over. Here are the steps you can try, each one more severe than the next:
First thing to try: Stop homebridge, delete everything in .homebridge/accessories and .homebridge/persist, and restart homebridge.
Second thing to try if that doesn't work: Stop homebridge, delete everything in .homebridge/accessories and .homebridge/persist, delete homebridge from your Homekit house, restart homebridge, and re-add it to your house (you'll lose assignment of devices to rooms.)
Third thing to try if that doesn't work: Stop homebridge, delete everything in .homebridge/accessories and .homebridge/persist, delete homebridge from your Homekit house, edit your config.json and change one of the digits in the "username" entry to be a different number, restart homebridge, and re-add it to your house (you'll lose assignment of devices to rooms.)
If none of those things work, then I'm really at a loss.
Sun Sep 24, 2017 8:36 am
Jim offline
The second thing fixed the issue. I deleted and re-added the homebridge accessory in the Home app. All the devices showed up and were responding. Now I just have to reassign to rooms.
Thanks for your time Mike.
Jim
Sun Sep 24, 2017 8:38 am
webdeck offline
I'm glad that worked! I wish Apple would provide more feedback to the user when things aren't working - it's all kind of voodoo to fix these issues...
