Alarm system support?
Wed Nov 30, 2016 5:02 pm
blysik offline
I see that HomeKit has support for the 'Alarm system' type. homebridge-envisalink supports it, for example. (https://www.npmjs.com/package/homebridge-envisalink)
However, I already use the DSC Alarm plugin -> envisalink, to let Indigo at my alarm system.
Is there any way to use DSC Alarm with homebridge-indigo so that HomeKit sees my alarm system "correctly" ? It would seem to require options in homebridge-indigo maybe?
Thanks.
Tue May 16, 2017 10:29 am
Ramias offline
Re: Alarm system support?
Just wanted to "bump" this. I'd like to expose alarm information in HomeKit via Homebridge. Since Indigo already connects to Envisalink, it takes up the only TPI connection allowed. So the homebridge-envisalink plugin would bump Indigo off.
Any way to add alarm sensor/event support to homebridge-indigo?
Thank you
Tue May 16, 2017 8:29 pm
Ramias offline
So over on Github for homebridge-indigo the readme shows fields for various alarm sensor types (treatAsContactSensorIds, Motion etc).
But the log file shows "Ignoring unknown accessory type Alarm Zone"
So looks like this may not work (yet). If I knew where to start I'd try to add it in. If support could be enabled that'd be pretty cool Thanks
Tue May 16, 2017 9:28 pm
webdeck offline
The device needs to support on/off through the Indigo RESTful API. If it doesn't, you would need to create a virtual device and use that instead.
However, without something like Homebridge Buddy on the Indigo side, homebridge wouldn't know whenever the device's state changes from outside of Homekit.
-Mike
