excluded ID still shows up in Home app
Posted: Mon Nov 21, 2016 2:04 pm
and more, it is an action group and shows up as a door!
Any idea how to fix this? I've double checked that the proper ID is listed as an excludeID and it is.
Also, I just edited my config.json to treat some things as switches, and then reran home bridge and got
but it seems to be running.
- Code: Select all
events.js:160
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
at Object.exports._errnoException (util.js:1026:11)
at exports._exceptionWithHostPort (util.js:1049:20)
at Server._listen2 (net.js:1257:14)
at listen (net.js:1293:10)
at Server.listen (net.js:1389:5)
at EventedHTTPServer.listen (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
at Server._publish (/opt/local/lib/node_modules/homebridge/lib/server.js:111:16)
at Server.<anonymous> (/opt/local/lib/node_modules/homebridge/lib/server.js:369:14)
