Indigo 7 and MyQ Update: Garage Door backwards in Homekit
Posted:
Sat Nov 19, 2016 9:31 am
by Ramias
I've installed the latest MyQ plugin for my Garage Door to support Indigo 7. The MyQ plugin now presents garage doors as locks in Indigo.
with the treatAsGarageDoorIds tag in HomeKit (so HomeKit recognizes these as Garage Doors even though Indigo says they are locks) the status is now reversed. My Garage Door is now Open, Indigo says Unlcoked, and HomeKit says it is Closed. (And vice versa for my other grade door).
Just wanted to throw this out there so the right folks are aware as new tweaks are underway for Indigo 7.
I suppose I could tell HomeKit to now treat the garage doors as locks, but it is nice that they correctly show up as Garage Doors.
Re: Indigo 7 and MyQ Update: Garage Door backwards in Homeki
Posted:
Sat Nov 19, 2016 10:09 am
by FlyingDiver
Ouch. I was afraid something like that might happen. When I changed the base device type from Relay to Lock, I had to reverse the logic in the MyQ plugin to get the correct status for the new type. Unfortunately, it's the way that Indigo does that mapping from on/off to lock/unlock that's causing it. I don't think there's anything I can do in the MyQ plugin to fix. I think WebDeck will need to do something different in the way he does the mapping when going from Lock to Door, the reverse of Relay to Door.
Posted:
Sat Nov 19, 2016 3:51 pm
by Ramias
I do like that it is consistent with locks -- locked/unlocked -- closed/open -- secure/unsecure.
Other than MyQ are there any other types of Garage Door openers that work with Indigo that a change to the Indigo HomeKit might impact?
Posted:
Sat Nov 19, 2016 4:29 pm
by FlyingDiver
I believe that there are both Z-Wave and Insteon garage door controllers out there, but I don't have one and I have no idea if Indigo maps them to a relay or lock device.
Posted:
Sat Nov 26, 2016 4:22 pm
by dougkillmer
I'm also using "treatAsGarageDoorIds" for my MyQ garage doors in Homebridge-Indigo. After upgrading, device status is reversed: locked=open and unlocked=closed.
Posted:
Sat Nov 26, 2016 4:57 pm
by dougkillmer
dougkillmer wrote:I'm also using "treatAsGarageDoorIds" for my MyQ garage doors in Homebridge-Indigo. After upgrading, device status is reversed: locked=open and unlocked=closed.
The Indigo Touch app shows the door as
Locked and
On, which really means closed. Changing the device to
Off will open the door.
- IMG_0215.PNG (68.97 KiB) Viewed 4585 times
Posted:
Sat Nov 26, 2016 8:11 pm
by webdeck
This appears to be a recurring problem that there is no consistency on how different devices map on/off to open/closed or locked/unlocked.
Currently, homebridge-indigo treats "on" =="open" or "locked" and "off" == "closed" or "unlocked".
I will work on adding a configuration that lets you reverse the meaning of on and off on a per-device basis.
-Mike
Posted:
Sat Nov 26, 2016 8:19 pm
by FlyingDiver
Now that Indigo has an official "Lock" device, that at least is set. I'm just hoping when they implement an "Open/Close" device that Closed == Locked and Open == Unlocked.
Posted:
Sun Nov 27, 2016 1:19 am
by webdeck
I just uploaded a new version to address this. It supports a new configuration parameter: "invertOnOffIds". The device IDs that you list there will invert the mapping of what on and off mean. So for example, for a lock, on normally maps to locked, but if you invert that device ID, then on will map to unlocked for that device. Let me know if you run into any issues.
To update, follow the instructions in this thread:
viewtopic.php?f=191&t=16904-Mike
Posted:
Sun Nov 27, 2016 8:02 am
by loafbread
This inversion will be very useful.
Posted:
Sun Nov 27, 2016 9:43 am
by dougkillmer
Thanks Mike! The door status is now displayed correctly in Homebridge.
Posted:
Sun Nov 27, 2016 1:00 pm
by Ramias
Confirming this works great now. Thanks for the assist.
