Available devices only if I use Homebridge :-D
Posted: Thu Sep 29, 2016 12:06 am
Hello everyone,
I'm configuring access from the Home app from my iPhone and my devices are only available if I use Homebridge D in Terminal.
I followed all the steps to use launchctl and although does not give me any errors, neither seems to work, my devices will not be available on my iPhone.
What I do is the following:
1. write "Homebridge D" in Terminal and intro pulse. Right now I can perfectly access to my devices from the House and manage iPhone application with Siri.
2. write Control + C "in Terminal to close the window. Naturally, the devices are no longer available.
3. write "launchctl load -w ~ / Library / LaunchAgents / com.webdeck.homebridge.plist" in terminal and do not receive any message, so I guess there is no error. Right now my devices continue without being available on the iPhone app.
This is the code of the com.webdeck.homebridge.plist file:
And this is de code of de runhomebridge file:
I can't send the log because I can't find this, its not create.
Can you think you may be going on?
Sorry for my english.
- Code: Select all
<plist version="1.0">
<dict>
<key>KeepAlive</key>
<true/>
<key>Label</key>
<string>com.webdeck.homebridge</string>
<key>ProgramArguments</key>
<array>
<string>/Users/anasanchezrabanal/.homebridge/runhomebridge</string>
</array>
</dict>
</plist>
- Code: Select all
#!/bin/sh
export PATH=/usr/local/bin:/opt/local/bin:$PATH
sleep 60
exec homebridge >~/Library/Logs/homebridge.log 2>&1
