HB still crashes for me 2-3 times a day.
Last log entry was probably after a computer restart 2 days ago
- Code: Select all
path.js:8
throw new TypeError('Path must be a string. Received ' +
TypeError: Path must be a string. Received undefined
at assertPath (path.js:8:11)
at Object.posix.join (path.js:479:5)
at Function.User.storagePath (/opt/local/lib/node_modules/homebridge/lib/user.js:30:15)
at Function.User.persistPath (/opt/local/lib/node_modules/homebridge/lib/user.js:38:25)
at module.exports (/opt/local/lib/node_modules/homebridge/lib/cli.js:24:17)
at Object.<anonymous> (/opt/local/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
I've restarted it manually many times.
On a similar note, I've tried to create a workaround where I have an action group that does
- Code: Select all
do shell script "/Users/macadmin/Documents/homebridgeStart.sh"
and even though I can manually do
- Code: Select all
./homebridge.sh
at the command line and it starts up fine, I can't make the action group work. No errors in Indigo, but no result either.
