I just received an RFXTRX433e to control my 3 Somfy solar screens from Indigo and they work great. I also plan to add an awning soon and control it the same way.
I can control them with Siri by turning on and off the device but that is not a natural way to issue the command. I would rather say something like Raise the Kitchen Shade. I think this requires adding a Window Covering service to homebrige-indigo. I had intended to attempt this myself but I've been away from it so long that I would have to relearn how to do it from scratch.
Mike, is there any chance you will be adding this service anytime soon? I think it's similar to the door locks we added before and should be straightforward. If you don't plan to do it, I might eventually give it a try but I'm hoping not to have to take all the time to relearn the process when it should be much easier for you.
Thanks either way.
--Dave
