HomeKit losing Connection
Sat Feb 06, 2016 11:55 pm
jamboinafrica offline
I am having repeated issues with my HomeKit losing the connection to homebridge and then forcing me to delete the homebridge device and then re-add to the setup again. This is obviously inconvenient as I have 80+ devices then to allocate to the relevant rooms in the house and also requires me to reset all of my HomeKit scenes.
The connection can last anywhere from several hours to several days and I am yet to find a consistent reason for the loss of connection. It almost always occurs when I stop and restart the homebridge app to add new devices but there have been numerous other times where there is no rhyme nor reason for it dropping out.
Any help would be much appreciated.
JIA
PS when it works, it is fantastic to have Siri work with my indigo setup - great piece of work!
Sun Feb 07, 2016 1:11 am
webdeck offline
Re: HomeKit losing Connection
JIA
Odd. I haven't seen that behavior, and I've restarted my whole server multiple times. Are there any errors in the homebridge output? What kind of server are you running it on? Make sure you don't delete the persist directory in ~/.homebridge - that's where homebridge remembers all of the HomeKit bindings.
-Mike
Sun Feb 07, 2016 2:34 am
No errors in the homebridge output at all and the devices are all still there in my iOS apps, just can't communicate with them (greyed out in the Insteon+ app for example). My server is a 2013 Mac mini running El Capitan.
I have not deleted the persists folder but have been tempted on occasion to try a new install and copy the old persists back across...
Sun Feb 07, 2016 9:27 am
nev offline
yea I have been running into this as well. It happens so often that I have an Indigo Action Group that kills and restarts homebridge. Then it all comes back. I have feeling its something to do with the frequency of "heartbeats" homebridge pushes out. If I leave the app open, sometimes it will come back and all devices will connect again, but most of the time, i use my restart button as i described.
Sun Feb 07, 2016 11:18 am
Unfortunately killing and restarting homebridge doesn't work for me...
Sun Feb 07, 2016 11:54 am
webdeck offline
What HomeKit enabled app are you using?
I'm also assuming you have your server setup so that it doesn't sleep, right?
Mon Feb 08, 2016 7:02 am
nev offline
I use one called Home for iOS.
https://itunes.apple.com/app/home-smart ... 94352?mt=8
As for the server, yea it is up 100% of the time. Its a MacPro running a lot of other stuff like Plex and its also hooked unto the TV for my media center.
Mon Feb 08, 2016 11:18 pm
webdeck offline
That's the same app I use. It could be something messed up with your iCloud account. Try following the instructions here to reset everything:
http://www.imore.com/did-your-homekit-home-disappear-heres-how-reset-homekit-sync
-Mike
Wed Mar 02, 2016 2:32 pm
DGJ offline
I'm having a similar issue but only after the 9.3 update. I've tried the key chain logout & logging out of iCloud etc.
I have to delete the persist folder then add the device again, it may last for an hour or two but eventually always fails and then I've to do the whole routine again.
It would be nice if there was a way of definitely deleting the stuff for home kit in the keychain!
Sat Mar 05, 2016 4:43 am
DGJ offline
Here's an update.
I was running IOS9.3 on one device and the general release on two other iOS devices, along with the "Home" app on more than one device.
While the Hue home bridge was happy with this arrangement the Homebridge wasn't.
I've upgraded two devices to 9.3 and that has helped while denying the other IOs devices access, I now only have the Home app installed on my main iPhone, this has stopped the Homebridge disappearing completely.
However I now lose some of my indigo devices after a while, this maybe 10 minutes or 10 hours and seems to be alphabetical! nothing after H appears!
restarting Homebridge cures the issue for a while but the bigger problem is they disappear from the room I've set up on "Home" and return to the default room.
I have no idea where to start on this issue as it doesn't seem to be a IOS HomeKit problem as some of the devices appear.
After some thinning out & excluding I'm down to around 70 devices & all work on initial boot up of Homebridge.
Annoying as the "hey Siri" is great and now I've some Estimote beacons it gets more interesting!
Sun Mar 06, 2016 12:29 am
webdeck offline
DGJ wrote:
Here's an update.
Did you update to the latest version as described here: http://forums.indigodomo.com/viewtopic.php?f=191&t=15685
