Variable not showing in folder
Wed Nov 14, 2018 12:16 pm
abplus offline
Hi Karl,
Here's the log print:
minMax                          Configuration: Dev-Name    DevID            State       ignoreLess   ignoreGreater tracking
minMax                          Weather Hourly Update; 506349862 ;        pressure      -9876543210      9876543210
Andrew.
Wed Nov 14, 2018 12:45 pm
abplus offline
Re: Variable not showing in folder
Here's the screenshot of the variables window
Screenshot 2018-11-14 at 18.44.12.png (100.91 KiB) Viewed 2549 times
Wed Nov 14, 2018 3:13 pm
Have you selected the measurements at the bottom of the menu?
Sat Nov 17, 2018 5:13 am
abplus offline
Do you mean the 'Define Device + Status to be tracked' bit ? Yes I have. If not, I'm not sure which menu you mean.
Sat Nov 17, 2018 5:22 am
abplus offline
The problem might be that I don't see the parameters list that is shown in your docs:
Screenshot 2018-11-17 at 11.21.24.png (210.73 KiB) Viewed 2472 times
Sat Nov 17, 2018 8:10 am
Did you load the new version from the plugin store?
That should show more.
And there should be a scroll bar
Sat Nov 24, 2018 8:43 am
abplus offline
Hi, sorry for the false alarm, I thought I was running the latest version but I was way off. I think I had the original dropbox download. Lesson learnt and all working fine. Thanks !
